![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
| TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 213
What did you use to get that fault code please? |
| Tomc Member Since: 15 Oct 2020 Location: Belfast Posts: 37
Hi all.
| Justin_Sherfy Member Since: 23 Dec 2019 Location: Washington State Posts: 8
That’s really cool you were able to fix it. 2012 HSE 5.0 V8 |
| JNC Member Since: 23 Feb 2020 Location: UK Posts: 293
I had similar experience. It lasted a few months before failing completely. Might be worth keeping an eye out for replacement and grabbing a bargain before you need one. |
Yeah thinking the same thing tbh.
| KDavies3 Member Since: 03 Jun 2020 Location: South Wales Posts: 4
| lostinespace Member Since: 19 Nov 2020 Location: Herts Posts: 59
Thank you for the write up, really appreciated. Anyone know if I can get the back of the seat in situ for 2009 facelift? 2009 TDV8 3.6 |
I don't know what the difference is in the 2009 upgrade is is I would imagine it's very similar to mine at 2007.
Thanks! 2009 TDV8 3.6 |
Brilliant thanks for everyone who has contributed just got my heated/cooled seat working on my facelift. Tips for getting the seat back off, the back pulls down once you have squeezed the bottom side tabs out over the metal pole. This is quite tricky I just used a long screwdriver from the bottom by the centre console. I nearly removed the seats after seeing Sam's Motors and Machines video yesterday, glad I didn't. I couldn't get the heater out without a bit more work, I just gaffer taped the 2" split works perfectly.
| jonty88 Member Since: 04 May 2021 Location: Derbyshire Posts: 5
Has the novel repair stood the test of time? |
Still working cooled seats great in the heat. 2009 TDV8 3.6 |
| misfire84 Member Since: 25 Nov 2020 Location: brecon becons Posts: 37
Have a look on my post in other section.
