Home > Technical (L322) > Water Pipe
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Water Pipe
Just wondering, anyone had to change the cross over water pipe on a 2011 model 4.4 tdv8?
Regards
Mark
Post #584374 18th Feb 2021 9:42pm
rjff
Can you pop up a photo of the pipe you are referring to? Lots of them and some do have problems. Cheers
Richard
Gap IIDBT
Post #584388 18th Feb 2021 10:47pm
Is that the crappy hard plastic one running over the radiator?
Post #584395 19th Feb 2021 12:16am
rjff
Wouldn't take odds on it not being that. Cheers
Richard
Gap IIDBT
Post #584419 19th Feb 2021 11:13am
Baltic Blue
Does he mean this one ?
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #584421 19th Feb 2021 11:25am
rjff
That's the £80 question Mr. Green Cheers
Richard
Gap IIDBT
Post #584423 19th Feb 2021 11:34am
nambFFRR
The plastic one between the vee under the plenum. I’m still losing a little bit of water and suspect it might be this pipe. The coolant is clear of any water emulsion so not suspecting head gasket. I’ll have to get my endoscope out and poke it in there!
Post #584574 20th Feb 2021 3:51pm
rjff
Not the usual one unfortunately.
See if you can identify it from the WM in the Wiki and perhaps others can suggest a cause for your coolant loss. Do have a poke around the expansion bottle as I understand it can cause a problem. Cheers
Richard
Gap IIDBT
Post #584585 20th Feb 2021 4:48pm
nambFFRR
Will do....thanks for the reassurance so fingers crossed
Post #584595 20th Feb 2021 5:42pm
mjdronfield
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #584599 20th Feb 2021 6:14pm
