Home > Maintenance & Mods (L405) > Courtesy lights- tail lights?
brutprestige
United States 2016 Range Rover HSE 3.0 SC V6 Corris Grey
Love the courtesy lights function for looking back at the precious in the dark. But why only the headlights remain lit? Is there an option to have the tail lights on as well?
Post #584947 23rd Feb 2021 2:27pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Tail lights also on here. But they stay on along with the DRL's all the time anyway...
Post #584948 23rd Feb 2021 2:31pm
brutprestige
Is that a setting somewhere only my headlights stay on, not even DRLs
Post #584956 23rd Feb 2021 4:24pm
adara
DAYTIME RUNNING LIGHTS (DRL)
With the lighting switch in the Off/Auto position, the Daytime running lamps will switch on automatically under the following conditions:
The engine is running.
The gear selector is out of Park (P).
The Electric Parking Brake (EPB) is not applied (is released) - market dependent.
Unless required or prohibited by law, the Daytime running lamps can be disabled or enabled. To disable or enable the Daytime running lamps, carry out the following procedure:
NOTE: In order to be successful, the procedure detailed below must be completed within 20 seconds.
Make sure the vehicle's ignition is switched off, and the lighting switch is in the Off position.
Switch the vehicle's ignition on.
Turn the lighting switch to the Low beam headlamps.
Turn the lighting switch back to the Off position.
Press and hold the rear fog lamp switch for more than 2 seconds.
Release the rear fog lamp switch.
Turn the vehicle's ignition off.
For my MY it doesn't work: Unless required or prohibited by law, the DRL can be disabled or enabled by a retailer/authorised repairer.
Post #584973 23rd Feb 2021 6:00pm
Re: Courtesy lights- tail lights?
You can turn your reverse lamp on on the CCF file 👍
Post #584988 23rd Feb 2021 7:08pm
DrRob
My L322 can illuminate reversing lights with a second press of the headlight button on key fob. Try it? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #584995 23rd Feb 2021 7:27pm
