![]() | Home > Technical (L322) > Dreaded water in the tyre well |
| jim4244 Member Since: 31 May 2012 Location: UK Posts: 855
It could be your top boot seal failing.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Powerful UK has a YouTube video on clearing all 4 sunroof drains. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433
Exactly...
| Calvey Member Since: 24 May 2020 Location: Bucks Posts: 13
Thanks DrRob. I had a look at the video and will have to check to see if the rear ones are blocked. sadly they don't show how to clear them, if they are. |
| Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 354
a quick way to rule out the sunroof drains i have used over the years is to seal the sunroof with Vaseline, it will create a watertight seal, leaves no mess if wiped down well and allows the sun roof to be opened, i did this with my D3 and it stopped all the leaks related to the sunroof then when the weather was better i sorted the issue out, if after doing this you still get water ingress its not from the sunroof drains 2012 Range Rover Westminster 4.4 TDV8
| maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58
Check for rear top hinges of top trunk doors. I had a water leak there, undo the top nuts and put some silicon under. |
| All times are GMT |
