Home > Maintenance & Mods (L322) > Plastic Car Ramps
Baltic Blue
Plastic Car Ramps
I have seen these ramps being used in several threads, so I asked father xmas for a set, but have only just got round to using them to level my car up on my sloping drive.
However I find the top platform a bit short and wonder if anyone has found a longer set .
I am considering trying to make a centre extension piece out of wood to extend them.
Any thoughts ??
Post #585288 25th Feb 2021 10:26pm
GGDR
Mike would it work better to turn them around and reverse onto them?
. Cheers, Greg
Post #585301 25th Feb 2021 11:17pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
They look like models for a hatchback. Are they really for the weight of a Range Rover and the size tyres? When I looked at ones suitable they were big, seriously big.
Post #585316 26th Feb 2021 12:23am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Amazingly you can buy these with a 7 ton rating Shocked
I looked in to these myself but was put off by the fragility of them, especially if your tyre presses on the stop at top. It seemed that most people recommended building your own out of wood but I'm not sure how these would fair on a slope 2011 TDV8 Vogue SE
Post #585343 26th Feb 2021 9:04am
DrRob
Mine have a slightly longer flat area and rated to 7 tons. Same as what Bodsy uses:
https://www.fullfatrr.com/forum/topic50147.html?highlight=ramps Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #585345 26th Feb 2021 9:21am
Baltic Blue
Thanks for the replies.
They are rated at 2.5 tonnes. I like that they are wider than the tyres so the weight is evenly spread, but just wish the top platform could be a little longer.
I tried them the other way round Greg, but no difference really, so think I will stick to this way because it is easier to see when I am nearer the top, and the front end of the car is dead level (as shown on spirit level). which is what I wanted for doing oil changes etc.
Post #585349 26th Feb 2021 9:38am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
have you thought of the leveling ramps used for Motor Homes and caravans?
https://www.leisureoutlet.com/levellers/ca...4YQAvD_BwE 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #585350 26th Feb 2021 9:38am
Baltic Blue
I have been in Heath Robinson mode this afternoon.
If I get 4 x 18” x 3” x7 “ pieces of timber and cut them as per my template I can increase the top platform from 11 inches to 23inches .
A 12ft length would make 8 pieces each 18” long, so just need lockdown to end and a trip to the timber merchants.
Post #585381 26th Feb 2021 3:58pm
Jayk69
i like it very much!! Thumbs Up 2012 Vogue 4.4 TDV8 - Current
Post #585385 26th Feb 2021 4:25pm
Bl4ckD0g
Nice work!!!
Post #585386 26th Feb 2021 5:01pm
Rob99
I can see that working really well............ Thumbs Up Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #585389 26th Feb 2021 5:37pm
darrenm
I have 4 of these rated 7 ton a pair
https://www.aimtools.co.uk/products/161918
Post #585414 26th Feb 2021 7:43pm
darrenm
Post #585867 1st Mar 2021 10:32pm
GGDR
excellent suction power !
Razz
. Cheers, Greg
Post #585870 1st Mar 2021 10:40pm
