Home > In Car Electronics (L322) > Possible gps problem |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7909 |
Pretty sure the part exposed doesn't want to be earthed so yes I think it will effect signal, tape it up, try to reroute it a bit and see how it goes... Pete
27th Feb 2021 5:08pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Is that a screened cable, can't quite make it out.
27th Feb 2021 5:26pm |
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 200 |
What do you mean by screened?
27th Feb 2021 5:49pm |
It's a screened cable.
27th Feb 2021 6:27pm |
Thanks
27th Feb 2021 7:47pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
Think of the inner core as a wire (it is ) the outer screen - the mesh - is another wire.
27th Feb 2021 8:20pm |
Brilliant thanks |
27th Feb 2021 8:27pm |
uzp315 Member Since: 19 Nov 2017 Posts: 428 |
Access the sat nav diagnostic screen using a similar method to way you do the other diagnostics on the screen - the 753 method. In this screen you can monitor the connections to the satellites and see how long it takes to connect and how many satellites you are connected to.
28th Feb 2021 11:47am |
Many current devices are now using the three systems simultaneously - GPS (American), GLONASS (Russian), and Galileo (European Space Agency).
28th Feb 2021 12:56pm |
You would think that wouldn't you? Apparently not. It was the USA military that maintained the satellites, and the news has reported for many years now that the support would cease. This is the very raison d'etre for Galileo. I am surprised that GPS uses three systems though as GPS uses NMEA protocol and I was not aware Galileo was intended to be compatible. Good news if it is though/ and I have not looked at the latest news on it for some years now. |
28th Feb 2021 1:10pm |
As I understand it, the three systems are being used independently and it is the receiving equipment which does the reconciliation. Not GPS using the other two.
28th Feb 2021 1:29pm |
Thanks Weegie, that has brought me up to date. I had no idea GPS III was even a thing. There is backwards compatibility so all that kerfuffle, back in the first decade of the 21stC, that led to Galileo was a storm in a teacup in the end; it seems there was no need for Galileo after all. |
28th Feb 2021 3:51pm |
