Home > Maintenance & Mods (L322) > Lanoguard under body rust proofing - I’m a convert!!!
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Hi all
With a good weather forecast I cleaned the underside of Silvia using a jet washer and an up turned patio cleaner. The results were good so yesterday was a drying off day.
This morning I started by removing the rear bumper and the getting underneath and brushing and remaining visible dirt away. I then warmed the Lanoguard and prepared the supplied nozzle that screws into the 5L container.
Here are the results:
I absolutely saturated every part of the underside and chassis. I also used the 360 degree wand to go into every nook and cranny possible. I then let the Lanoguard dry and gave it another coat. This is how much I used
It was as simple as spraying WD40. No mess and no covered in black like the last time I used Waxoyl.
All in all I’m a convert!
Jim
Post #585678 28th Feb 2021 4:08pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
jim i am going to do this in the summer.
can i ask if you have painted your back box and if so what with? 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #585681 28th Feb 2021 4:46pm
Jases4x4
United Kingdom 2010 Range Rover HSE TDV8 Santorini Black
Im going to do this soon it was either this or dinitrol as this last longer im told but maybe alittle messier spraying that, I wonder if using some sort of degreaser would be best to spray on first or just a blast water from the jet wash, did you clean it first with anything?
Post #585683 28th Feb 2021 5:14pm
jim4244
I sprayed my rear box with Rustoleum Matt black spray paint. I just jet washed it and let it dry first.
I cleaned the underside using a rotary patio washer that I turned upside down. I place the head of the washer in an old washing up bowl and pushed and pulled it around the underside. It did a surprisingly good job!
Previously I owned Discoveries throughout the 1990’s and early 2000’s. I a.ways ended up Waxoyling them but is was just so messy and such a faff. This stuff is simple.
If I were to buy the kit again all I would buy is the 5L container with the supplied hand sprayer and the probe.
Jim
Post #585693 28th Feb 2021 6:12pm
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
Good pics, Looks a good job and sounds easier and cleaner than Waxoyl. Might give it a go when I get round to it! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #585695 28th Feb 2021 6:32pm
V8_Disco
Jim
You could not go for the grease/wax ? As well ?
Aidan
Post #585696 28th Feb 2021 6:50pm
jim4244
I decided not to go for the tub of grease as I wanted to be able to see what is going on with the chassis in the future. The spray is really easy and clean and appears to coat and creep very well.
Jim
Post #585698 28th Feb 2021 7:06pm
V8_Disco
Thanks - i will be placing an order tomorrow for think
Post #585701 28th Feb 2021 7:16pm
darrenm
I have cleaned and checked mine still all good 14 ish months on
Post #585824 1st Mar 2021 4:53pm
jim4244
I bet that it was simple to spray the chassis with your car in its roof.......😅
I was going to ask you over on FB if you belonged to the FF forum 👍
Jim
Post #585825 1st Mar 2021 4:59pm
darrenm
Yes made it so much easier when my 12 year old has finished home schooling I will ask her to turn them around
Post #585827 1st Mar 2021 5:03pm
