![]() | Home > Technical (L322) > Restricted Performance red triangle |
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464
It is a distinct possibility it may need the turbo drain mod done. Once youve given it the beans does it stop smoking?
| Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352
sorry it doesn't smoke at all from the exhaust even when you give it the beans i meant from around the back of the engine after switching off, i was told by the garage who did the oil cooler to expect this for a while whilst it burns off any oil left from the leaking oil cooler 2012 Range Rover Westminster 4.4 TDV8
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Take it back and get them to check it’s not still leaking.
If code is P040D then it’s an exhaust gas temperature sensor in the passenger side manifold
ill double check the code in the morning, im going to call the garage as they are replacing the belt tensioner that has a dry bearing noise hopefully this week, i popped the bonnet and a lot of burnt oil smoke came from the back of the engine for a few mins so ill get them to check, when i popped the bonnet and went to remove the engine cover i noticed it was split just above the front lhs clip im sure it wasn't split before it went in |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 965
Coincidentally, I replaced both gaskets on my oil cooler today (and the two feed pipe o rings) - when replacing the assembly back onto the engine, the lower gasket *could* drop out of its groove and potentially not seal once bolted down - I lifted mine back up a couple of times just to be 100% it had stayed in place.
| dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450
Do you know if they also replaced the o rings on the oil feed pipe at the rear of the oil cooler. If you follow what Dr Rob has suggested you will be able to see the pipe going into the oil cooler, shine a torch on there and see if it's clean. You should be able to get your hand down there and feel the nut that hold the pipe to the cooler, give this a wipe, is it clean and free from oil? 2011 TDV8 Vogue SE |
And the O rings needs to be Viton ones. Specificiation in the Wiki write up. BS something or other.. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
I did mine recently (In the last 2 weeks) but after advice from my Indy replaced the whole cooler as they are prone to warping and still leaking after the change. I could not tell you if mine was warped i did not check and another member on here has it now.
I have several spare viton o rings of the correct size if you want to change them in any case, once the engine cover and plenum are removed (< 2 mins.) it’s a relatively easy job to do. Let me know & I can pop a couple in the post |
My cooler was replaced too and not just the gaskets |
thanks for the offer its booked back in on tuesday next week, they replaced the oil cooler with a genuine one, i did mention the o rings at the time but said i need them to double check everything next week 2012 Range Rover Westminster 4.4 TDV8 2006 Discovery 3 HSE 260k miles and still going strong with a new owner |
| All times are GMT |
