![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal |
| nigor Member Since: 28 Jan 2020 Location: Tallinn Posts: 13
And as stated in first post
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
nigor: It's got absolutely nothing to do with saving the world, I think you're missing the point, I'm trying to save your engine that wasn't designed to have the egr/dpf removed. If you want to delete them, carry on, it doesn't worry me in the slightest what you do, have the gearbox remapped & blow the |
Wow! How to make friends and influence people!!! |
I think you should also learn some manners dear boy, people on here are trying to be helpful & you are bordering on being rude. This is a wonderful forum with great people with huge amounts of knowledge, again, people are only trying to help. I'll leave it there & will not revisit it. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
Nigor, No mate, if you remove the EGR and DPFs I understand the exhaust temps and other stuff do not get managed properly. I don’t mean from a conservation point of view, I mean from a heat under the bonnet point of view.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
| Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147
Our South African cars have EGR with CAT but without DPF.Would like to know about the EGR remove.
| kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 86
No news on this front? |
| Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342
Let's bear in mind we've never had anyone come forward saying they have successfully deleted EGR and DPF on a 4.4.
I hear you mate.
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404
The DPF's function in not to filter out soot created from the EGR. Soot is mostly created under load which is when the EGR is shut anyway. |
That's where you're wrong my friend.
If I'm wrong then the whole of the motor manufacturing industry is wrong as well |
| All times are GMT |
