Home > In Car Electronics (L405) > Screen Issue
FishersRR
United Kingdom 2015 Range Rover Vogue SDV8 Barolo Black
Screen Issue
Hi All,
I have a 2015 Range Rover 4.4 SDV8. The centre screen (radio/nav etc) is temperamental.
Start vehicle, screen loads up as normal to home page but touch screen does not work. The screen functions as normal (current location changes, heated seats screen pops up when button pressed etc) but the touch screen is not receptive.
Drive vehicle for 5-10 minutes and switch off for a few minutes then back on, touch screen works perfectly.
Thinking logically, I don't believe it can be the touch screen itself as it does work. A local RR specialist has confirmed no software update available. They have suggested new head unit (part number LR079586 and manufacturer number FPLA10E889AK).
Has anybody come across the issue before? Is there anything else I can try?
Many thanks
James
Post #586068 3rd Mar 2021 6:25pm
i had a similar problem with my 2012 westie...turned out it was low battery power, replaced battery and all was well.. ... - .- -.
Post #586076 3rd Mar 2021 7:05pm
FishersRR
Thanks. Not experiencing any other starting issues. Did you?
Will test the battery with a multimeter next time I start the car.
Post #586089 3rd Mar 2021 7:40pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
The main battery or the backup battery in the head unit (if one exists). I am having trouble with my navigation initializing for 10-30 minutes prior to the map showing up. If I turn the vehicle off, it initializes again.
My main battery was quite low yesterday when I bought the vehicle due to sitting on a dealer lot for six weeks.
Thank you,
Dan
Post #586112 3rd Mar 2021 9:40pm
FishersRR
I’ve just pulled the fuse for the screen and put back in. The screen worked without driving the car.
Will check again in the morning. Is there anyway to wipe/return to factory settings the head unit?
Post #586119 3rd Mar 2021 9:58pm
FishersRR
Started the car this morning, screen not working and then pulled the same fuse, no luck unfortunately.
Looks like it will need to go back to Land Rover.
Post #586161 4th Mar 2021 8:22am
