Home > Maintenance & Mods (L322) > Front to rear break pipes
Ianb4310
So sadly my 2006 RR. has failed it’s mot on front to rear break pipes ☹️
Can anyone give me a idea how long a Landrover indie should take to replace them so I’m for armed/warned
And a rough cost of parts
Cheers
Post #586252 4th Mar 2021 4:52pm
What are you going to ask your to do sir? Replace like for like? Or make replacements in copper?
Copper will be more time consuming to make whereas JLR parts will require a greater strip down and therefore more work to fit!
FYI there are factory joins just behind the NSF wheel splash shield... Thumbs Up
Post #586259 4th Mar 2021 5:11pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
had mine done last year in copper think it was about £250 all in plus mot Thumbs Up
Post #586281 4th Mar 2021 7:35pm
D3Jon
4 hours labour at most for a decent garage to tackle this (probably less if they've done it before) + £10's worth of Cunifer pipe. If rear flexi's are replaced at the same time, then another £40 at best (if they use non genuine), so all up I'd be happy to pay an indy around £300 for this job.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #586300 4th Mar 2021 9:32pm
mjdronfield
Pretty sure I paid £280 ish in January. Mine had actually split though, so pedal went soft. Went down further which stuffed the seals in the master cylinder. Needed a new one of those, so total Bill about £669.
Get them changed before they split.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #586307 4th Mar 2021 9:54pm
Ianb4310
Thanks everyone I’ve been quoted £220 plus the vat so happy with that by OFG Lincoln
Post #586311 4th Mar 2021 10:14pm
D3Jon
Sounds like a great price. It'd be worth them doing the rear flexi hoses (which are part flexi and part steel which corrodes) at the same time if they arent already.
Should then give you many years trouble free from rear brake pipe issues.
2014 Disco 4 HSE
Post #586316 4th Mar 2021 10:45pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
If you intend to keep the car, I would replace the flexis with braided stainless steel ones. Will last forever then. Did this on my D3 when I replaced the brakes all round (discs, pads and callipers)
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #586344 5th Mar 2021 9:40am
Ianb4310
I’m going let OFG check it out and see what they recommend then let them go for it !!
Probably going to keep it for 18mth to 2 years till my son finishes university then go for a lot newer RR don’t think I can stretch to a L405 so the last of the L322s
Post #586420 5th Mar 2021 8:14pm
