Home > Technical (L322) > Reduced performance
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Reduced performance
Good evening all I have the dreaded reduced performance back on the full fat and again I’m looking for advice I have cleared the codes they go away for a couple of days then returns I have taken a snap shot of the faults that I think are responsible.
Thanks in advance
Post #586424 5th Mar 2021 9:56pm
Sleepy Jen
United Kingdom 2008 Range Rover Vogue TDV8 Zermatt Silver
I have had issues with the U0415 codes on other vehicles (BMW/VW & Audi); 9 times out of ten it was to do with wiring or connectors for the ABS/speed sensors, or the sensor its self. In two cases the plate in the wheel bearing that the ABS sensor reads was at fault - new bearing/hub assembly required.
Bad or intermittent signals from these sensors can have an indirect effect on a number of other systems in the car. From experience this has included faults on: Engine, traction control, instrument pack, cruise control module, gearbox, airbags etc., if you can think of a system that may use wheel speed, even indirectly in its control methods it has the potential to show issues.
It is possible but unusual to have the ABS module at fault.
Another area to look at is earth connections - in the connectors and body grounding points, especially if the car has seen alot of weathering and damp conditions leading to corrosion and poor grounding.
Start with the cheapest and easiest items to check first if you are unable to trace the fault in more detail by reading individual sensor outputs/inputs with the software you are using.
Good luck.
Post #586428 5th Mar 2021 11:07pm
GGDR
these look like typical codes that come up from time to time but don't look like restricted performance codes.
how's your battery?
Your IID shows 14.7v with the engine running, what's your voltage with engine off?
. Cheers, Greg
Post #586450 6th Mar 2021 9:31am
Simran0211
That’s great thanks sleeply Jen Thumbs Up
Post #586452 6th Mar 2021 9:32am
Simran0211
I’ll check that out and display cheers GGDR
Post #586453 6th Mar 2021 9:34am
Simran0211
Just done a battery check 12.2 but it did flash across to 12 then held steady at 12.2
Post #586459 6th Mar 2021 10:12am
rjff
I'd go with Greg.
But what's the engine fault code and is it a yellow or red RP fault. Cheers
Richard
Gap IIDBT
Post #586481 6th Mar 2021 2:33pm
Simran0211
Can you please excuse my ignorance what is the yellow or red RP FAULT please
Post #586515 6th Mar 2021 8:01pm
rjff
I'll stand to be corrected, but a red can come up if the DPF is blocked and it says vsit dealer, power is reduced and it's a slow acceleration to about 50ish. ISTR it may raise its head if you have a leak on the air inlet sides.
A yellow that I've had has no real reduction in pulling power, but was a water in fuel fault, P2264-00 28
HTH Cheers
Richard
Gap IIDBT
Post #586518 6th Mar 2021 8:17pm
Simran0211
Cheers Richard Thumbs Up
Post #586558 7th Mar 2021 10:20am
rjff
You're welcome S.
As Sleepy Jen says, have a look at the earths on the car and connectors to the control units/sensors.
If I think of anything else I'll post up. Keep us all in the loop as to what you keep finding. Cheers
Richard
Gap IIDBT
Post #586574 7th Mar 2021 12:11pm
Simran0211
Ok I had a play with the abs loom and the restricted light went out, only to come back on later. I seem to get 10 miles out of her before she throws her teddy bear 🧸 out of the pram. I have to say before I bought her I had the forsite to getting an IID unit which is already paying for its self.
Post #586653 7th Mar 2021 10:55pm
rjff
Sounds as if you are on the way. As we have the same model I'll follow this with interest. I'm bound to get the same fault sooner or later. Rolling Eyes Cheers
Richard
Gap IIDBT
Post #586674 8th Mar 2021 11:57am
Simran0211
Quick update it’s been fine for those last couple of days so fingers crossed 🤞also I got the dpf cleaned it did a auto regenerate and this afternoon I floored it and the amount of blue smoke out the rear was embarrassing but it seams to have cleared Thumbs Up
Post #587728 16th Mar 2021 11:49pm
