Home > Maintenance & Mods (L322) > Tailgate rust prevention
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
3 years on and going strong (touch wood) no more bubbles.. all good..
When I sprayed it, I left the boot open and tilted downwards to allow the excess come out of the wee holes. I definitely recommend the product. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #586440 6th Mar 2021 7:01am
darrenm
I did my 2010 when the tailgate got replaced in 2014 after someone damaged it still rust free si it’s deffo worth the effort
Post #586465 6th Mar 2021 11:06am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I did the same job last weekend and used Lanoguard 👍
Jim
Post #586476 6th Mar 2021 1:28pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
following just noticed bubbles on mine!! 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #586486 6th Mar 2021 3:29pm
Maccaa
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Jim
Jim, I believe Lanoguard is colourless/opaque ?, may I ask does it smell and which kit did you buy to do the tailgate, did you use the 360 sprayer?
Ta
Maccaa Current FF Westminster 4.4 V8
Post #586948 10th Mar 2021 3:16pm
jim4244
I bought the 5L with a 360 probe sprayer.
I’ve done the full underside and chassis, rear wheel arches, sills internal and external and tail gate. I still have just under half left, so around 2L.
I smells a bit “sheepy” until it cures but not to bad. Nowhere near the amount of mess compared to waxoyl!
Jim
Post #586953 10th Mar 2021 3:37pm
Maccaa
Jim thanks Jim, just what I wanted to know. did you use the 360 in the tailgate too? Current FF Westminster 4.4 V8
Post #586955 10th Mar 2021 3:50pm
jim4244
Yes. As far up either side as I could and all along the bottom.
Jim
Post #586957 10th Mar 2021 3:59pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Having done a tailgate replacement this week, I'm currently choking on the fumes of the waxoyl that has now drowned the replacements interior
Post #586972 10th Mar 2021 7:49pm
jjfang
United States 2012 Range Rover HSE 5.0 V8 Santorini Black
Lanoguard is similar to what Fluid Film/Wool Wax here in the US. Thats currently what im using, but my issue is that it drips none stop in the summer since it stays "fluid". I have a donor rust free tailgate from another Rover that was also painted the Santorini Black like mine (Super lucky). Im debating if I want to keep my tailgate on until mine rust through or just replace it and spray a different rust inhibitor since its rust free so I won't get the drippage from the stuff I spray
Post #591623 18th Apr 2021 5:44pm
DrRob
It will pass....I used Dynax on my top tailgate and it stank for a few days...
I sprayed it through the drain holes and rammed my probe in to the max Shocked Rolling with laughter Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #591637 18th Apr 2021 6:20pm
jjfang
Would this be something you would touch up maybe annually? They say its a waxy/soft finish that can self heal, are you able to confirm if this is really the case? I found two articles that say interesting test results. Im deciding between Dynax S50 or Noxudol 700 and the first link shows Noxudol finishing first and Dyanx in 5th but then in the second link in a test for Dynax it looks like Dynax did really well but Noxudol not as well. Curious to get peoples thoughts!
https://www.auson.se/wp-content/uploads/20...y_uk_1.pdf
http://www.bilthamber.com/media/downloads/PG-BH13-001.pdf
Post #591680 19th Apr 2021 3:45am
