![]() | Home > Technical (L322) > Drivers Side Heater Stuck on Hot |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 ![]() ![]() |
One thing to check would be heater valve solenoid. Should be on the right side near wheel arch(if you stand in front of the car) |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1041 ![]() ![]() |
You be wanting 1 of these then.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3331 ![]() ![]() ![]() |
Thanks guys.
Mine was the same hot on drivers side all the time.
Thanks Dave.
Yep its tuck in the in the middle of all the hoses, just unbolt it and lift it out dont worry about bending the hoses there rubber after all. You will lose a bit of coolant I just put a funnel on the end of each hose and poured it straight in before connecting it to the solinoid valve unit saves getting air locks |
Thanks Dave, I’ll get one ordered up tonight and will have a bash at fitting it when it arrives |
I finally got around to fitting the heater valve this afternoon.
