![]() | Home > Technical (L405) > Anyone recognise where this little cover might be from?? |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1071 ![]() ![]() ![]() |
A random guess, but perhaps a cover for a seat belt reel? I think Lear make seat belts. |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Do a Google search on the part number and see if that narrows it down.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35747 ![]() ![]() |
i did that .....it doesnt |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 623 ![]() ![]() ![]() |
Yeah, first thing I tried too. But went back following Andy's guess and tried via LEAR who do seem to make automotive seats in Coventry so maybe possible but the trail dried up pretty quickly. Had another look around the car but couldn't get at the SB reels without serious dismantling which I'm not interested in doing so I'll just put it in the automotive junk box in the barn for now... Mike - MPx
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 ![]() ![]() ![]() |
Is it the flap behind the inside door pull unlock handle? It is curved and needs popped out to get access to the bolt behind it which keeps the door card on.
Very good call, thanks,....but no. Same size and general shape as the rear ones although the leading edge is a slant rather than square and on mine they are matt plastic whereas this piece is shiney. Mike - MPx
Treebor99 Member Since: 07 Feb 2021 Location: Rugby Posts: 34 ![]() ![]() ![]() |
The OBD port cover? Anything can be made to work if you fiddle with it long enough (and have deep pockets|)
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3295 ![]() ![]() ![]() |
Might be worth sending an email to Rob at Duckworths with the part numbers on it and see if he can find it in the parts catalogue.
Treebore99 - Interesting in that my ODB port doesn't have a a cover - its not clear whether it should or not. On the L322 it was a fairly robust hinged cover but there's nothing like it on this L405. Do other L405s have an ODB port cover? Regardless, the hole over the port is not the same shape or size as the piece of plastic pictured above.
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 848 ![]() ![]() ![]() |
There is no cover over the OBD port - interestingly, in my car at least, there is a secondary location, closer to the door, where the OBD port could also be fitted... Again, not covered...
Yeah, i did see it has a curve after I posted so figured it probably would be OBDB.
Agree it seems most likely seat or seatbelt related, but nothing visible without doing any dismantling. Mike - MPx
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Just a thought, the piece does looks very like an OBD port cover.
