Home > Technical (L405) > Sorry folks.... another FBH question
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
Well I bought a 2014 4.4 AB at the weekend, its glorious !!! Magic carpet, BA first class with a sledge hammer built in.
However as is no great surprise I've already found an issue.
The FBH isn't working. The first easy fix was a new battery in the key fob. I get the green flashing light to confirm "operation accepeted" or whatever the handbook says but nothing happens. If I try a manual start vis the screen the button shows red...then quickly goes back to white, no not working.
Previous experince would suggest low voltage but the car doesn't give any other indications that would be the case (nor did the L322 either come to think of it)
How do I access the data screen on the L405 and what voltage is deemed enough ?
Or is there another common issue with the FBH on these ?
Post #586745 9th Mar 2021 10:03am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
They will not operate if temperature is too high . Been warmer recently down your way ?
Post #586746 9th Mar 2021 10:05am
Ragingrover
I did wonder but it was about 5 degrees yesterday first thing, that can't be too warm can it ??
Post #586748 9th Mar 2021 10:18am
Mr Tee
Had a quick search and some mention 5 degrees is the cut off .
Post #586764 9th Mar 2021 11:49am
Ragingrover
Thanks, I tried a quick search myself but didn't find much. However if it's right then great and also its typical for me to try it when on the temperature cusp ! LOL
Post #586770 9th Mar 2021 12:33pm
Chris1573
Just been through all this with mine.
First thing to do is try to manually fire the FBH. If you look behind the rear panel in the boot on the R/H side then you will find the receiver that your Key Fob communicates with. There is a three pin plug that goes into this and the antenna connection. If you unplug the 3 pin plug then you have the three wires... ignore the Brown that is the negative. But if you bridge the Red (+VE) to the green (Signal) then you will be sending a signal to the FBH. Keep them bridged and you should hear the FBH start up and also the blower in the car should start up. (might need you heater controls turned up). If nothing happens then its onto the next stage.
Have just been through all this so happy to help !
 L322 2007 TDV8 3.6
Post #586771 9th Mar 2021 12:37pm
andygts
The water pump failed on mine. If you've got access to a scanner plug it in. Mine was throwing up a fault code for the pump and was fixed under warranty. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #586773 9th Mar 2021 12:42pm
Ragingrover
Is this for the L322 ? I'm L405, however my "maybe not a problem at all" is it won't work when manually operated at the screen unit.
I'm going with the "its me at fault" and not the car given what Mr Tee has helped with.
Post #586775 9th Mar 2021 12:45pm
Chris1573
Ahh Sorry did not see the forum was L405.
Just pretend I never posted Smile L322 2007 TDV8 3.6
Post #586776 9th Mar 2021 12:49pm
