![]() | Home > In Car Electronics (L322) > 2006 l322 key problems |
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 ![]() ![]() |
I had a very similar problem with a aftermarket key! I sent it back to Boyd at pixels fixed and he synced it to his Range Rover for the central locking and tailgate which it did then sent it back to me I then tried it and it synced 1st time!
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Cheers Ian, ( That was quick )I did wonder about the number of keys synched and wondered about a limit, but my diagnostic reader did not give any info like that. Hence I do not know how to delete old keys. Thinking about it, that may be the way to go. Maybe I need a better diagnostic tool, or have to go to a dealer or specialist.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Code readers may sync but won’t code keys to cars. And generally won’t be able to retrieve security codes for them either.
Thanks for your time and info gents, much appreciated, I realised that the code reader could not sort out the keys, and it looks like you are right, I will have to have the old key entries deleted, so to speak. Next job to find an auto locksmith in my neck of the woods who can do this. That way I can get two new flip keys at the same time.
Contact Boyd Beattie @ pixels fixed on Facebook he’s mobile and can do everything you want great guy and fantastic service |
Just be prepared that they shouldn't be travelling from Scotland at the moment |
Thank you Ian and Blackdog, much appreciated. I think I have found a local outfit to carry out said work.
No worries that’s what it’s all about helping each other 👍 |
![]() Good luck with the keys ![]() |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
Some of the old style keys do not support the learning mode of the EWS system and need to have their remotes hard coded. The keys actually have 3 separate things - 1. A key blade to fit the lock barrel 2. A transponder to unlock the immobiliser 3. The remote for the car's convenience functions (I.e. remote unlock).
GaryRR and all, thank you for the help, this started out as a simple task and nearly there.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Someone put a link up to an Aliexpress seller who cuts the blade from a photo, have searched here but cannot find a link and cant find them an Aliexpress, can someone help? 2007 TDV8 VSE
There's a locksmith on eBay who will cut a new blade from your photo and send you an upgraded style key for £30:
Thanks but I am in Australia so quicker and cheaper to get on direct from China 2007 TDV8 VSE
