Home > Maintenance & Mods (L322) > Smoking Brakes
Jon G
United Kingdom 2011 Range Rover Vogue 4.4 V8 Baltic Blue
Smoking Brakes
Got back from a short trip last night and noticed smoke coming from the Nearside Rear Brake.
Took it apart tonight and the Pistion is totally seized in the Caliper.
Haven’t had the Drivers side apart but I’m going to replace them as a pair anyway.
So guess what I’m doing tomorrow after a quick trip to the Motor Factors 😭😭😭😭
Post #587227 12th Mar 2021 8:06pm
this does happen, hope the repair goes well. ... - .- -.
Post #587228 12th Mar 2021 8:17pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
It seems to be happening to a lot of them. I’ve had my rear callipers replaced the other week. One day when I got back I felt like getting the fire extinguisher 🤣 they were so smoking hot. Sadly I left it to late so it was callipers, discs and pads doe me.
Post #587229 12th Mar 2021 8:30pm
Merchy
As you said, change the pair, good move. No idea this post will apply to you?
When working on brakes , carefully remove rubber piston sleeve, clean side of piston and all surfaces, then use a mix of Coppaslip or generic branded copper grease, dilute with a small quantity of hydraulic oil, ie brake / power steering oil ( Compatible with rubber seals, as some oils / lub oils will degrade some types of rubber. ) coat exposed area of piston etc, and refit rubber sleeve. I tend to keep cars for a long time and found this method helps to arrest corrosion and prevents seizure
Using a copper based grease as opposed to a molybdenum based grease,is best as copper based lubricants have better heat resistance. Adding a minute amount of oil reduces the viscosity of the mix and prevents it becoming like a paste. Molybdenum based lubricants tend to become quite viscous and have the opposite effect to that desired and collect particles of dirt.
Time consuming, but best of all a cost effective fix, nice and cheap, just like me. Thumbs Up
Apologies to some if I seem to be teaching 'Granny to suck eggs' but I realise that many on this site have no engineering background, so will not know standard tricks such as this. As for the members on here with no engineering background who tackle some very technical jobs on their fatty, hats off to you gentlemen, some of the oily bits still scare me! Bow down Bow down
Post #587244 13th Mar 2021 12:26am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Think mine need doing on my 53 plate v8. Nearside squeals like hell when reversing and even worse if I put the trailer on so decided to order pair of calipers tonight and new pads. Looked at cheapo parts and they want £350 for a pair of rear calipers
Post #587247 13th Mar 2021 1:12am
Remember, don't use copperslip on aluminium callipers, use the correct brake grease. Thumbs Up
IIRC the rear calliper seals will not come off without removing the pistons, so don't just pull them off without looking.. Thumbs Up Pete
Post #587271 13th Mar 2021 10:26am
Jon G
Thanks Guys.
Worked out at £160ish for a both Callipers once I get the refund back on taking the old ones back.
Job done this morning without any hassle.
All bled up great and no more smoking brakes 👍👍👍
Post #587354 13th Mar 2021 8:20pm
