Home > Technical (L405) > Tire Pressure Sensors Not Reading after replacement!!!HELP |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 |
What error message is showing?
11th Mar 2021 12:21am |
vishnugnair Member Since: 10 Mar 2021 Location: Dubai Posts: 4 |
Well the tmps error orange light is lit.
11th Mar 2021 7:44am |
johnf Member Since: 16 Nov 2012 Location: Nottinghamshire Posts: 84 |
I had problems with mine - turned out they were in transit/shipping mode and needed to be activated. This stumped a local tyre fitting place who could see the sensors on their diagnostic tool and couldn't understand why they weren't working. My Landrover dealer sorted it for me.
11th Mar 2021 3:28pm |
so whats the way to send a 125khz modulated signal to the tpms sensor? pretty much stuck at first base even after going through the above link !! |
11th Mar 2021 5:56pm |
You need the "right" TPMS tool. There is another thread here with a discussion on this: https://www.fpaceforum.com/threads/experie...ode.39729/
11th Mar 2021 6:03pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
You generally need a bidirectional tools and higher up the range. I'm pretty sure the Autel 608 upwards can do that, or my favourite the Xtool X100 PAD2 or 3...I'll double check whether I can set mine to ship mode... |
11th Mar 2021 6:10pm |
does anyone know the original part number for the tire pressure sensor monitoring system for the range rover vogue?
13th Mar 2021 5:30am |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 205 |
Part number LR070840 or Jaguar C2D47173
13th Mar 2021 9:53am |
Bear in mind that there are two frequencies used by Landrover for TPMS - 315 and 433MHz. I'm not 100% about this but think European cars tend to use 433 and non-European 315 -at least for some model years. Your part number/sensor might therefore be different depending on country. My UK car uses LR070840. |
13th Mar 2021 10:03am |
