Home > Technical (L322) > Fuel Compensation TD6
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Can anyone explain the fuel compensation across the various cylinders please?
Can it be used to indicate or diagnose injector faults?
Why do most cylinder have figure around 650mm3 but usually one or two others with 2 mm3?
Thanks
Post #587258 13th Mar 2021 9:14am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
If it’s any consolation I have the same.
I went as far as installing 2 brand new injectors which made no difference whatsoever, apart to my bank balance....🤨
As far as I’m concerned all cylinders should read the same or similar unless I’m missing something?
The strange thing is I haven’t noticed any loss of power?
Jim
Post #587264 13th Mar 2021 10:03am
