Home > Maintenance & Mods (L405) > 2017 L405 Wiring harness for Radar Present?
garrettwp
United States 2017 Range Rover TDV6 Corris Grey
I'm wondering if anyone can confirm if a 2017 L405 without ACC still has the wiring harness for the radar unit? In pictures on 2016-, I see it's clipped right in the center of the cut out. I looked for this without taking the front bumper off but didn't see it. Not sure if it's still using the same wiring harness or not. Looking to retrofit ACC but don't want to pull the trigger on a radar if the wiring isn't there.
I am aware that GAP doesn't support CCF programming on 2017+ yet, I'm using Pathfinder.+ a CCF editor to push changes.
Post #567959 25th Sep 2020 6:30am
garrettwp
After taking off the bumper and thoroughly looking, I can confirm I do NOT have the wiring harness. I have the SE model so perhaps they have a couple different looms or switched just for '17.
Post #587140 12th Mar 2021 4:52am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
This is a bummer as I removed the grille and tried to look at mine and there seems to be no loom either...
 2019 Vogue P400e
Post #587151 12th Mar 2021 9:19am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I don't know if this helps, but my 2013 Vogue has the wiring in place and was clipped to the cut-out in the crash-bar.
I've now fitted the radar (it needed a bracket, but very simple to fit - just plugged in) and added the switch pack to the steering wheel, but not got around to re-programming the CCF yet. Current:
- 2013 L405 4.4 TDV8 Vogue
Sold:
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #587428 14th Mar 2021 1:49pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
It seems that for 2017 onwards the wiring loom is customised to the vehicle spec to a great degree which makes retrofitting things like remote climate and adaptive cruise a lot more difficult.
Post #587448 14th Mar 2021 5:21pm
