Home > Technical (L322) > Pipe location on l322 range rover vogue 4.4 tdv8 2010
Shawser1203
United Kingdom 2010 Range Rover HSE TDV8 Zermatt Silver
Anybody know where this pipe goes. It's under driver front wheel arch, looking up to alternator are.
Post #587436 14th Mar 2021 3:52pm
Baltic Blue
Can you see if the breather pipe is connected to the starter motor ??
Just a guess .
Post #587438 14th Mar 2021 4:12pm
Shawser1203
Thats a better veiw of it. Just seems to be hanging there. Nothing close to connect to. Maybe just a breather?
Post #587440 14th Mar 2021 4:25pm
Merchy
Don't know why or where, but looks like a compressed air 'fast fit' coupling on the end of the hose / pipe.
Maybe someone added a compressed air testing line ? Has the piece between the fast fit coupling and hose got a built in ball valve ? Maybe a slotted screw for operating a ball valve ?
Post #587443 14th Mar 2021 4:51pm
Shawser1203
Took connection off pipe. Just an open end. Very strange.
Post #587452 14th Mar 2021 6:12pm
Edward
It connects to the engine mounts. Should be a pipe coming down which connects to that plastic end.
Post #587949 18th Mar 2021 8:27pm
Shawser1203
Ah cheers for that. So what does the pipe actually do?
Post #587992 19th Mar 2021 10:38am
rjff
There's a description in the WM/engine/electronnic engine control/locations with diagram. Here's the text. HTH
ACTIVE ENGINE MOUNTS
The active engine mount system comprises:
Two engine mounts
Vacuum control solenoid
Connecting vacuum pipes
The ECM controls the engine mounts via the vacuum control solenoid. The mounts are on (i.e. Solenoid activated which makes
mounts soft) at idle speed, and are switched off when the engine speed goes above a predetermined threshold. The threshold
is temperature and engine speed dependant, above 20ΒΊ Celsius the mounts are switched off when the engine speed increases
to 900 rpm. Below 20ΒΊ Celsius the mounts are switched off when the engine speed increases to 1150 rpm. Cheers
Richard
Gap IIDBT
Post #587995 19th Mar 2021 11:03am
Shawser1203
Thanks for that bud. πŸ˜πŸ‘
Post #587997 19th Mar 2021 11:07am
rjff
You're welcome. Thumbs Up Cheers
Richard
Gap IIDBT
Post #587998 19th Mar 2021 11:10am
Shawser1203
What would the problems be with this pipe not connected?
Post #588180 20th Mar 2021 7:03pm
rjff
Perhaps this may help found it on a search for car active engine mounts.
https://www.autoevolution.com/news/engine-...12732.html
Not quite what you asked, but may be a start. Thumbs Up Cheers
Richard
Gap IIDBT
Post #588257 21st Mar 2021 3:46pm
Shawser1203
Cheers for that. Do you know where the solenoid valve is located for the vaccumm pipes?
Post #588314 21st Mar 2021 9:15pm
rjff
Sorry I don't ......yet.
One of the members will no doubt be good enough to tell Razz Cheers
Richard
Gap IIDBT
Post #588328 21st Mar 2021 10:59pm
Shawser1203
πŸ˜πŸ‘
Post #588329 21st Mar 2021 11:05pm
