Home > Technical (L322) > battery drain & HVAC panel
aterkut
Turkey 2008 Range Rover HSE TDV8 Java Black
my 2008 TDV8 is also one those L322s which likes to drain battery with a little help of HVAC fan in control panel
I have changed "final stage resistor" with new but nothing changed - did a test by putting a little tissue paper over little grill on HVAC panel, left it overnight with doors locked and tissuepaper was still there in the morning - means that little fan inside HVAC control panel was working all night and sucking air
my genius idea is just putting a "XXX minutes delay relay" to cut-off voltage to fuse number 12 in glove box (which controls "Air conditioning, Heated seats - front") after ignition is off
I have read that, if I do that, the only thing will happen is loss of memory of HVAC panel's last configuration
but temperature control is manual!! so I will be leaving them in preset position always and after I turn on ignition in the morning the only thing I need to do is just pressing AUTO button or turning knob for fan level
point is, am I wrong with my genius idea or is it acceptable?
Post #587243 12th Mar 2021 11:58pm
uzp315
I imagine you are aware of this:
Fast forward to 6:20 and listen to what Harry says about the button:
https://www.youtube.com/watch?v=gl51reRXxgE
No idea how this works, but it sounds like it leaves the HVAC system on.
Mark
Post #587511 15th Mar 2021 9:38am
aterkut
I havent mentioned about that PROG button - I am talking about middle knob when you press it and it auotmaticly adjusts fan spped and vent mode...
Post #587514 15th Mar 2021 9:44am
uzp315
I wasn't trying to tell you which button you were talking about. I was merely pointing out one way the HVAC system may stay active.
Good luck.
Post #587515 15th Mar 2021 9:45am
aterkut
got it - the best is to take action and try
Post #587516 15th Mar 2021 9:46am
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
If you want install this "XXX minutes delay relay", then why don't just connect it to the little fan behind the HVAC dash? No worries about losing settings.
Just my two cents
Post #587528 15th Mar 2021 10:53am
aterkut
hvac panel is full of 2008 model technology elecrtronics and I didnt want to touch that piece - just want to shut off it
Post #587529 15th Mar 2021 10:57am
