![]() | Home > Technical (L322) > Reduced performance P006A fault - solved |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Ive had a reduced performance fault come up since stripping down to do the idlers.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
Hi Rob
Thanks for the advice gent's, I'll give the other sensor on doughnut a clean also.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
manifold inlet replace is a pig. it involves the injector leads coming off etc. Mine cost £1600 all in for pax side only. |
Let's hope it's not that then Dolphinboy!
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3313 ![]() ![]() ![]() |
I'd say that's pretty well caked up. As far as I'm aware all of the little holes should be clear.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
mine had 2-3mm of crap on it when i cleaned it. I only cleaned it as i was changing the oil cooler and had no faults other than the customary oil leak. |
Ok, so looks normal ISH!!
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1329 ![]() ![]() ![]() |
I have to clean mine about every 2000 miles!! and it has far more on it than yours has. Thing is it still runs ok!! |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4341 ![]() ![]() ![]() |
I cleaned mine by spraying with brake cleaner until all 4 holes were clear. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
There is a separate thread somewhere about the throttle body fitting. Try taking the silver clip off and tightening it between fingers then refit it. I replaced the whole unit with a brand new one and it was still a little loose onto the ali throttle body Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3860 ![]() ![]() ![]() |
I clean mine every 6 months at the same time I do the oil service, just as a way of remembering to do it.
Rob
Subject to being able to test drive it once I replace the front air springs & calliper I’ve hopefully found the issue.
