![]() | Home > Technical (L322) > C1130-66 Suspension Fault |
The RR Bandit Member Since: 31 Oct 2019 Location: Teesside Posts: 29 ![]() ![]() ![]() |
Problem solved:
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
good stuff |
jjfang Member Since: 13 Nov 2020 Location: Chicago Posts: 45 ![]() ![]() ![]() |
How did you isolate which front bag? Im having the same issue, I currently have the negative terminal pulled to see which side drops, I figured if it valve block both will drop, and if it only one then one corner will drop since it can't auto level with no voltage |
