![]() | Home > Technical (L322) > L322 2010 error P2453 ? |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
There are 2 sensors if I remember, before and after the exhaust. I would get underneath (you don't need a ramp) and have a look at the exhaust area and that the sensors are connected properly (they may have been dislodged by road debris/snow/slush?).
sergeiicz Member Since: 20 May 2020 Location: Caslav Posts: 47 ![]() ![]() ![]() |
thanks
so a swap that DP sensor on bank1 - error gone but after 250miles I want to check that again if everything is ok .. but its not
What engine size do you have? 3.6 or 4.4? I suggest you get a HIGH pressure test done first to see if there are any obvious leaks.
its 3.6 sir and yes high pressure test done twice
the fact that it's not regenning properly may suggest that it's not getting up to the temps required. This can be caused by a gate (turbo or EGR?) staying stuck open or the thermostat staying open. These engines run very cool so they need to pump Diesel fuel into the DPF filter to raise the temps. May be causing your problem but to be honest I am not sure and don't have the technical knowledge required. good luck. |
