Home > Technical (L322) > Rear Discs
Chris1573
Rear Discs
Hi I just fitted new disc and pads on the rear. The EPB shoes looked ok so I left them as is. After fitting the new discs i tightened up the adjuster till they gripped then backed it off a few clicks till the disc freed up. Is there anything else I need to do or is this it... Have read about a bedding in process but not sure if it applies or how to do it as the Workshop manual I downloaded has a link to to an external site that I cant access.
Thanks all. L322 2007 TDV8 3.6
Post #587918 18th Mar 2021 5:46pm
dhallworth
If you scroll down to the bottom of this page there's links to the workshop manual that you should be able to see.
https://www.fullfatrr.com/wiki/Main_Page
Post #587919 18th Mar 2021 5:55pm
Or, if you have an IIdTool, it will do it for you Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #587920 18th Mar 2021 6:01pm
Chris1573
David.
Yes I downloaded the manual David. there is a link in there to an external JLR site that I can access. L322 2007 TDV8 3.6
Post #587926 18th Mar 2021 6:34pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
If you didn't change the EPB shoes, there's no need for the bedding process - which is more for the EPB shoes than the discs Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #587931 18th Mar 2021 6:56pm
Chris1573
So just tighten up the adjuster till they grip then back off a few clicks till they don't Pawl ? Smile L322 2007 TDV8 3.6
Post #587936 18th Mar 2021 7:07pm
Pawl
There is a specific quanity of clicks to back-off I think - probably to ensure the EPB applies the correct tension to the cable.
I can't remember what it was, maybe 5 or 6 - more than I was expecting when I did mine a couple of years ago.
UPDATE : It's actually 8 ! That's why I thought it was a lot !
Copy from WM :
 Paul,
Post #587941 18th Mar 2021 7:31pm
Chris1573
Bow down Bow down L322 2007 TDV8 3.6
Post #587946 18th Mar 2021 8:02pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
I replaced the disks and pads earlier this year but not the EPB pads, I did have to go through the palaver of the resetting of the pads for the handbrake. not difficult but does take a bit of time and I don't think doing it in the centre of a city or town works. I did mine on a rural road, it did take about 8 or so goes to get the brakes set, it did pass an MOT so I must have done something right.
Post #587947 18th Mar 2021 8:11pm
Sleepy Jen
United Kingdom 2008 Range Rover Vogue TDV8 Zermatt Silver
There is a good how to video on You Tube from Powerful UK Ltd - Land Rover Discovery 3 & 4 bedding in rear handbrake shoes EPB. It is for a Disco 4, but the sytem and procedure is the same for L322's.
Link:
&list=WL&index=10
Post #588188 20th Mar 2021 7:55pm
Chris1573
Thank you SJ... L322 2007 TDV8 3.6
Post #588216 21st Mar 2021 8:20am
