![]() | Home > Off Topic > Need a heavy duty drill - any ideas? |
essex boy Member Since: 21 Jan 2017 Location: essex Posts: 214 ![]() ![]() ![]() |
Hi
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
I agree - I have a 10 year old Screwfix special SDS drill that cost me less than £50. It is heavy but it just works!
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
If you are drilling 20mm or bigger holes, one option is to ask at tool hire places for Sds drill machines for machine anchor bolt holes etc basically a huge hammer drill, ie Hilti drill. They will get the job done quickly.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Yup. I still have my Hitachi SDS and a set of drill bit that are very long and never used used after that one job. If you were near you’d be happy to borrow it.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
Bought a Titan SDS drill from Screwfix when doing up the house. Good heavy duty piece of kit, knocked down lots of walls in chisel mode and drilled lots of holes in concrete and bricks. Worked out loads cheaper than hiring as it was available whenever I needed it, didn’t need collected or returned. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Cheers guys (sexist assumption i know!)
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
I bought the cheapest corded from screwfix, Christ it’s heavy, but does the job . |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
If you are doing loads of holes cordless drills are useless.
If you're getting a hammer drill always get a rotary hammer drill rather than a hammer drill. The difference is you can turn the hammer action off with a rotary hammer drill. This makes them a lot more versatile and also they're much more reliable as they don't use a cam action for the hammer.
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 ![]() ![]() |
Try cheap percussion drill with rotary and hammer actions. I bought one about 12-years ago in B&Q as it was on offer with a whole lot of cheapo electric gear close by that had what appeared to me at the time (with years of property developing behind me even then) to be Martian hieroglyphic writing and decors and no identifying names on them!!! |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 155 ![]() ![]() ![]() |
There is only one powerfull drill on the market: HILTI!
I can second Ansi's comment on the 'Hilti' kit, expensive but superb.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
My Hilti`s are 30 years old and just as good as when I bought them? If you want something to last it will cost? |
