Home > Technical (L322) > Battery disconnected - all faults cleared?
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
I've had an amber EML and a frequent "Reduced Performance" error on my 2010 5.0 SC recently. The car was booked in for a different job to be done and I was able to not use it whilst waiting for it to go in. However, during that time I fitted a towbar, mainly so that the towbar coding could be done while it was in.
In order to connect the towbar electrics, as a precaution I disconnected the battery for a short time while I plugged the electrics in.
When I went to drive to the garage for repairs yesterday, I had a completely clear dash, but what's more annoying, they have plugged it in and said that there are no fault codes stored at all! Surely the codes are not wiped by a battery disconnect?? I though they were stored for x-number of ignition starts or something like that?
The errors are bound to recur as soon as I get the car back, which will mean another return visit. On the plus side I have just bought an IID tool so at least I'll be able to read them I guess. 5.0 S/C Autobiography - now gone to pastures new....
Post #588601 23rd Mar 2021 9:38pm
When does it drop into reduced performance, any particular thing you are doing..?? Pete
Post #588611 23rd Mar 2021 10:03pm
Cappo
Nothing, it's completely random, and when it first started doing it there was no discernible drop in performance either - but then it seemed to get worse. I pulled away from some lights, not that hard, and it bonged and threw the Reduced Performance message and nearly stood on it's nose with the loss of power! That was when I stopped using it, it's now with a decent indie (AHL) but they can't read any faults from it. 5.0 S/C Autobiography - now gone to pastures new....
Post #588612 23rd Mar 2021 10:15pm
Mine started to do that but only when at full throttle (mostly), showed no codes and the reduced performance reset by restarting it... It did it numerous times before it left a fault code P0087 low fuel pressure...
The JLR workthrough was filter, pressure sensor and lift pump... all changed, still did it...
I hit the US Jaguar forums as they use this engine far more than we do and found four similar cases which were resolved by new mechanical fuel pumps
Mine is sat in pieces as we speak as I change the two high pressure mechanical fuel pumps,...
You can use the IID for real time values and monitor fuel pressure which should show a drop before it goes into reduced performance... Pete
Post #588616 23rd Mar 2021 10:48pm
Mine sometimes bonged and said reduced performance but ran fine with no loss in power... I think your problem sounds similar to mine... Pete
Post #588617 23rd Mar 2021 10:50pm
Cappo
It does indeed Haylands, thanks for this. If the garage don't/can't find it this week I'll have to monitor, knowing that the IID will pick up your symptoms is helpful to know. 5.0 S/C Autobiography - now gone to pastures new....
Post #588620 23rd Mar 2021 11:09pm
