![]() | Home > Technical (L322) > I was told to steer away from a 4.4 TDV8 and get a 3.6 TDV8 |
| Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322
Nonsense and old wife tales. Just get what you want and find yourself another mechanic |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Use a different mechanic as he's talking crap.
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
I don't wish to disrespect your 'Land Rover' mechanic....but.......codswallop! Is he a 'mechanic' who works on Land Rovers or is he a trained 'Land Rover' mechanic....there's a subtle difference.
Dr Robs first line says it all & exceeds all my waffle! |
| Johannes Member Since: 24 Mar 2021 Location: Haapsalu Posts: 4
Thanks for you input! I shall ignore the “advice” given by that mechanic and will continue searching for the right 4.4 TDV8 RR for myself |
See the Wiki for a DIY guide and loads of other support
Split opinion on the oil cooler leak on here, some replace just the seals/gaskets & some [me] changed the whole cooler because the time allocated for the job is around 4.5hrs. It's do'able if you're handy with the spanners [which I'm not] so my thought was, if it's all apart change the whole cooler & forget about it. Others will say just change the seals & gaskets....your choice. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
not heard of cranks failing on the FF |
as for Oil cooler i am with Fox889 for the cost of the new cooler and the time and effort i was going to (I did it myself) to strip down it was a no brainer. the whole job took me and my 11 year old apprentice 5hrs. with plenty of tea as it was freezing bloody cold |
| TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 672
Even the 3.0 crank issue is super rare in a FFRR - it’s a Range Rover, your taking your chances either way |
| IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 301
Your "mechanic" wouldn't happen to have a 3.6 TDV8 for sale that he wants to get rid of would he?
No he did not offer a 3.6 for sale |
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494
Rubbish. Mmm.... Yes and no. The new 3 litre diesel is the engine which is known to suffer from crank failure and features in the L494 Sport and L405 FF. However, I've tried researching this before and there are no statistics available on crank failure rate. You need to bear in mind that more than 90% of diesels sold by Land Rover were the 3 litre and not the 4.4L and therefore, the incidence of people reporting problems on forums and In chat is also going to be 10x higher than for the 4.4L. I've driven both and in my opinion, the 3 litre is the better car. It's plenty powerful enough, quiet and economical. The 3 litre is a fantastic engine - my dad has it in his XF. The 4.4 adds a lot of weight to the front of the Range Rovers, which noticeably impacts the handling (as well as your wallet) and for those reasons, on the newer Range Rovers, I feel the 3 litre is the better option. So anyway, back to the L322 - The diesel choices are a 3.6 Ford V8 up to 2009 or a 4.4 Ford V8 or the petrol choices were a 4.2 Jaguar V8 or a 5.0 Jaguar V8 (the latter of each feature on the current models). Both diesels have their share of problems, both in a cared for state will do quarter of a million miles. BUT, the engine bay is crammed full enough as it is with the 3.6L, I dread to think how time intensive and difficult repair jobs are on the 4.4L and, I feel this would also make repairs more expensive as you're realistically looking at putting it into a garage for most jobs, instead of being able to do these on the driveway. However, the 4.4L is a more refined beast and the 8 speed box is what would clinch it for me so, although I have a 3.6, the refinement of the 4.4 would win hands down. Just bear in mind it may not be too frugle compared to the 3.6 around town and, driveway repairs may be difficult. |
Thanks for that insight! I am currently also eyeing the L405s and especially the 3 liter diesel. I´m wondering if the crank issue on the 3 liter diesel is something that can be avoided with a preventative fix in the garage?
