Home > Maintenance & Mods (L322) > L322 3.6 tdv8 2010 noise |
Jases4x4 Member Since: 29 Jan 2021 Location: Yorkshire Posts: 10 |
Mine does exactly this, about 5 seconds and its like a rocking squeaking sound, its got to be a pulley or tensioner maybe even fan slowing down. Its done it 5 years i have had the car. |
21st Mar 2021 12:25am |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 369 |
Mine does this I think it is the turbo actuators or EGR valve or both going through a self check, think they also do it at start up but you can't hear it then over the engine.
21st Mar 2021 6:06pm |
Mines definitely not any of them, this is a bearing noise from fan or a tensioner. |
21st Mar 2021 6:13pm |
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 |
Mmm. Originally I was thinking it was idle wheel or tensioner but this noise is after shutting down. Do engine is stationary its like something is free spinning for about 5 secs after engine stops. I'll try and get video. |
21st Mar 2021 11:24pm |
This is exactly what mine does the noise is after the engine stops 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
22nd Mar 2021 6:16pm |
The only other thing spinning is the fan. Everything else will stop. if it’s the fan spinning it could mean the viscous coupling has gone fubar....
22nd Mar 2021 9:14pm |
Sounds like mine is the fan noise, its like as the fan slows down the noise does around 3 seconds i counted after engine stops. Would a new fan fix this? If so i might get a new fan belt aswell dont think mine has ever been replaced and now on 113,000 on clock. |
22nd Mar 2021 9:22pm |
briangunn Member Since: 19 May 2019 Location: London Posts: 56 |
The high pitched hum and squeak squeak squeak sound is the engine management repeatedly cycling the throttle bodies to clear them of any soot deposits.. |
22nd Mar 2021 11:02pm |
Ooooo so this is normal then. No further action. |
23rd Mar 2021 10:35am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1340 |
This sound is entirely normal. It's the EGR valves and throttle bodies doing their reset cycle (They reset each time you turn the engine off and take the key out)
26th Mar 2021 11:06pm |
Boodle Member Since: 15 Jun 2022 Location: Bristol Posts: 2 |
Hi all,
15th Jun 2022 4:20pm |
Yes, that's exactly it.
15th Jun 2022 4:24pm |
Ok, is it even worth trying to oil them? is it even possible? |
15th Jun 2022 4:28pm |
The throttle bodies are on the front of the intake manifold. To give them a proper clean would involve removing it, which is a pain in the backside, as it usually also involves unplugging various sensors, removing the heatshields and unplugging some of the injectors. Cleaning may only take 30 minutes but removing and re-installing when you haven't done it before can easily take over 3 hours.
15th Jun 2022 4:35pm |
