![]() | Home > Technical (L322) > Battery problems |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
Sounds like it’s set to go on using the timer function, you should be able to cancel this via the setting screen on your nav system. L322 2007 TDV8 3.6 |
Greyskull Member Since: 13 Jun 2019 Location: Selby North Yorkshire Posts: 49 ![]() ![]() ![]() |
Hi thanks for your reply, yesterday I had to move the car to put the bin out but before I could do this I had a problem not enough power in the battery I put a volt tester in the socket and it was 10.7 volts.. that day I took delivery of a starter pack a topdon volcano2000 jump starter I watched loads of videos on utube they look good it states it’s for 10 lt petrol and 8 lt diesel so plenty of power charged it up,and it barely spun the engine over maybe 4 seconds ... I disconnected it waited a few mins as per instructions as I coupled it back up the car was like disco lights flashing on the dash indicators head lights flashing all sorts of noises from every were in car under bonnet took it of waited a bit tried to start car same again it could barely turn engine over then nothing the jump starter was down to 2% from 100% ..ARE THESE JUMP STARTERS COMPATIBLE WITH RANGE ROVERS AS THEY SEEM TO HAVE A DELICATE ELECTRICS ....I THEN PUT THE BATTERY ON A GOOD CHARGE AND IT FIRED UP .. I WENT OUT TODAY TO BRING BIN IN AND THE FBH WAS RUNNING AGAIN LOOKED ON NAV SYSTEM ALL OFF PLEASE WATS THE FUSE FOR THIS FBH ,A COLD CAR IS BETTER THAN ONE WAS DOSENT WORK 😁😁😁 |
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
From memory it's fuse 59 in the glovebox but check your owners handbook to be sure, as there are sometime variations.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
Interested to find out if it is the external heater. |
Thanks again will av a look tomorrow has anyone had any problems with these jump starters..I checked on nav and the settings are all off......👍👍 |
I actually have the Topdon Volcano 1500.
