Home > Technical (L322) > M62 4.4 Coolant leak from cap
Page 1 of 3 123>
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Now that I replaced the leaking water pump, I'm facing another issue. There's a very small coolant quantity slowly escaping from the expansion tank cap. It appears that some quantity is being let out at some point but not continuously.
I replaced the cap with a spare one I had but it doesn't make any difference.
Due to the previously leaking water pump, I have developed the habit of filling up the tank a little bit more than what is indicated as "full". Specifically to the point that it just covers the indicator's horizontal bracket / guide. Which gave me more time between refills and a level reference. Both caps, the one original to the car and the newer one are of the 140 marking.
Am I actually causing this by overfilling? Are both caps bad? Or are they incorrect and should be using a 200 one?
Thanks
Post #588921 25th Mar 2021 6:33pm
Ask Robin at Duckworths to check but I thought the 140 cap was only for the first couple of years, IIRC yours should have the 200... I maybe wrong but worth a check... Thumbs Up Pete
-Click here for Thread-
Post #588947 25th Mar 2021 8:23pm
vs322
I'll definitely ask around to make sure I have the right cap fitted.
Thanks.
Post #588956 25th Mar 2021 9:06pm
D3Jon
I agree with Pete.
LR changed to the higher pressure cap and a different cooling system design on the M62 V8 around 2004. You'd have to supply your VIN number to a LR dealer to obtain the correct cap for your car.
Some web sites claim the cap is the same for all 2002-2006 vehicles (when Jag engines came in) - That's simply incorrect.
Not only did the cap's pressure rating change from 140Kpa to 200Kpa (20psi to 29psi) , but the cooling system design also changed (different thermostat housing, some pipework changes as well around the water pump).
BMW / LR brought about the changes to run higher pressure and coolant temps in order to decrease emmissions.
Some of the guys on the Bimmer forums change their cars to run the 140 Kpa system as it's generally thought to be more reliable and less likely to blow hoses (especially the heater hoses which can be a bit suss).
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #589026 26th Mar 2021 11:55am
vs322
Thanks for the advice, much appreciated
Just spoke with the local dealership and they said the 140kpa is the correct cap
Vin # SALLMAMA44A1XXXXX
By the way, just noticed a very slight leak from the below quick coupling
The amount of piping and associated couplings in this cooling system is just insane... Laughing
Booked her with my mechanic for Monday morning. Will pick up a new cap and hose from the dealership on my way...And we' ll finally fit the new front air struts. Wink
Post #589031 26th Mar 2021 12:45pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
what thermostat have you got in it
mine is a 2005 and had a 105deg thermostat i think it was, i changed it to a 85deg i think it is
a lot of people have done this, it helps with over heating and takes the strain off the system with the 140 cap RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #589045 26th Mar 2021 3:00pm
vs322
When I replaced the pump, I also replaced the thermostat. I used the 105 Deg., identical to the one removed.
Post #589048 26th Mar 2021 3:07pm
Do your Range Rover a big favour and fit one of these to yours, especially as you are in a hot place...
Item here...
https://www.ebay.co.uk/itm/80-C-Thermostat...SwlzVa19e6
A good thread here.. Whistle
https://www.fullfatrr.com/forum/topic39362.html
Thumbs Up Pete
Post #589054 26th Mar 2021 4:38pm
vs322
Hey Pete,
Thanks for the tip. I had been thinking about this mod for quite some time.
From page 3 of the thread I understand there's an 88 Deg. direct fit Behr thermostat, am I getting that right? If yes, I could just swap it out on Monday.
I should have done my homework as it's less than two months since I changed the thermostat along with the water pump. Banging Head
Post #589070 26th Mar 2021 7:25pm
The original fit ones were hard to get hold of and very expensive when I fitted the kit...
It's very well made, fits perfectly and uses very cheap thermostats which you can change should you need to...
You have to be careful with the lower temps as you may go too far and the fuelling won't go into closed loop.... not good..!!
Thumbs Up Pete
Post #589090 26th Mar 2021 9:08pm
vs322
Considering I paid 100+ euros for the standard one I just replaced, I'd say that cost isn't an issue. Even at that price, It isn't something you change very often. What really matters is having an improved system running within spec / manufacturer tolerances.
Post #589095 26th Mar 2021 9:25pm
knares
i fitted a BMW one, cant remember what model it is off RR 2005 4.4 petrol
Post #589145 27th Mar 2021 1:57am
p38arover
Australia
<snip>
Unless I can't read MicroCat correctly, that appears to be incorrect.
It appears the 200kPa cap was fitted up to VIN 1A001049 and the 140kPa cap thereafter.
PCD000070 (CAP) [ (V)1A001050 - ]
PCD100200L (CAP) [ - (V)1A001049 ] Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #589148 27th Mar 2021 3:18am
p38arover
Australia
This interests me as I have moved from a 200kPa cap to 140kPa and changed the thermostat to an 88 deg C item. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #589149 27th Mar 2021 3:22am
vs322
That is correct, sir!
Also confirmed by my local LR dealership.
Post #589154 27th Mar 2021 6:50am
Page 1 of 3 123>
