Home > Off Topic > Expandable Garden Hose |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 396 |
Why shouldn’t you use one ? Does it cause an issue?
25th Mar 2021 9:44pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Rob, I’ve killed two kaerchers that way with leaky motors. Got to say Nilfisk didn’t have such issues but had others. I think the issue is the back pressure when letting go of the trigger and it has nowhere to go. Putting additional strain then on the pressure washer motor and seals. Nearly all my hozelock connectors all had a non return valve. So this time for my K7 I got the kaercher connection kit and wouldn’t you know. It includes a hozelock style connector with aqua stop but without a non return valve. The machine is very smooth indeed. Hopefully I now have many years of pleasure from it. |
26th Mar 2021 5:56am |
Hmm,May need to look at it then. Don’t use it very often so may not be apparent for a while.
27th Mar 2021 11:32am |
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 |
Yeah got one of dem too! OK for two years then it started spraying you at the variant spray nozzle end - possibly as we leave it in an old plasticky rubbery bin outside the shed in ALL weathers. I guess the frost has gotten to it... the hose is still OK though with little seepage. Might try putting some clear silicone all around the spray gun join/s seam/s to eke another few years of use from it. |
26th May 2021 11:19am |
