![]() | Home > In Car Electronics (L322) > 2006 3.6 Bluetooth not working |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3269 ![]() ![]() ![]() |
The white cables that you have taped together form part of the fibre optic ring and should go in and out of your phone module.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
I have the original plug for those fibre optic cables however, that doesn't match the shape of the empty socket on the phone module? |
That’s odd.
Do you know what's missing where the white sticky pads are? |
If your car is a Vogue SE, it’s where the DVD change would be I believe.
Weirdly, it's a Vogue but, in SE spec. The only thing it doesn't have is the rear headrest entertainment.
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
Hi Gary, unplug the multi pin plug on your bluetooth module, looks for signs of blue corrosion on the pins... L322 2007 TDV8 3.6 |
If you've not got rear seat entertainment then you won't have the 6 DVD changer.
Thank you.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
If it turns out to be the module, I have one from a 2007 VSE for sale no corrosion at all |
I have tested tonight and the module is dead.
The Nokia one isn’t great when it comes to connecting newer phones, occasionally you need to reconnect the phone every time you get in the car.
Maybe the newer one then. I think the part is 8H2210F845AA . |
