Home > Maintenance & Mods (L322) > IID switched extension lead
DrRob
I recall a thread but cannot find it..spent ages so no moaning at me Whistle Rolling with laughter
Anyone got a link/links to it?
I remember it had an in line swith and folks tucked it and the IID up near feet Thumbs Up
Might be an idea to remove the door cover to avoid snapping it off by mistake? Whistle Big Cry
https://www.ebay.co.uk/itm/114473326584 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589319 28th Mar 2021 9:49am
i'm pretty it was Mike [baltic blue] that talked about these...i cant find the thread either!!.. ... - .- -.
Post #589339 28th Mar 2021 11:19am
DrRob
It’s within a DPF one I think.....yes, Mike Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589349 28th Mar 2021 12:24pm
Baltic Blue
Mines not got a switch, but Greg installed one the same way with a switch.
I leave my lead permanently plugged in with the flap permanently open, but the cable wedges it so it’s not flapping.
I was worried about wearing the plating on the car socket by constantly plugging iid in and out.
The leads are very cheap on eBay. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #589350 28th Mar 2021 12:26pm
DrRob
Any pictures so we can then maybe Wiki this idea? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589381 28th Mar 2021 5:00pm
Baltic Blue
I will take some snaps tomorrow and add to this thread, just opened a bottle of red Rolling with laughter
Post #589382 28th Mar 2021 5:04pm
Range Rover L322
Easy to run it under the driver footwell trim. I broke one hinged OBD cover when it was hanging down and replaced it (I think it was more than £100!), so now I tuck it up out the way using blu-tac. It can't be seen.
The IIDTool sits next to the driver seat where it also cant be seen. The switch is easily reachable.
Also if you leave it plugged in, it is vital you switch it off or it will drain the battery. Hence the "On" written on the switch.
https://www.amazon.co.uk/gp/product/B073Y2...&psc=1
Post #589383 28th Mar 2021 5:09pm
DrRob
ebay one is a lot shorter than the Amazon one....just be aware Thumbs Up
Next job on list to do plus new front brakes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589444 29th Mar 2021 10:34am
Merchy
Thank you folks, cracking idea, now added to my 'to do list'. Also saves kneeling on the driveway to plug in carefully to avoid damage to the docking plug.
To plug in safely once I am in the car, I'd have to be a bloody contortionist
The 'ON' mark is a good idea, ( To avoid my senior moments Whistle )plus I will wrap the end plug in a bit of cling film to stop dust and crap getting inside. Thumbs Up
Post #589456 29th Mar 2021 1:21pm
GGDR
Yes was me and mine is pretty much the same as RR L322 above.
Leaving the IID plugged in can drain your battery (ask me how I know!)
One day I did leave it on and it paid dividends -just as my MOT was being completed they reversed it off the ramp and a warning came up.
The guv was not happy;
Mechanic: I swear that wasn't there before guv,
Guv: you can't let it go with a warning light...
back and forth continued while took out my phone and cleared the error discreetly.
Then I leaned in, looked at the dash and asked 'them both "what warning light?" Whistle
Was a few quid off Ebay. Mine is wired to the rear of the normal socket leaving the normal socket non-functioning. Can easily be put back. Cheers, Greg
Post #589464 29th Mar 2021 2:42pm
DrRob
I routed mine round and its completely hidden. Cable tied it and the IID to a round bar on the front of the seat frame. Used a small cork pad to mark the ON side so I can do everything by touch.
Post #593562 8th May 2021 8:18am
DrRob
I also cable tied the OBD door flap open via one of the vents in the kick panel Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #593563 8th May 2021 8:19am
DrRob
Removed mine. It was not letting the iid read all the ecus for some reason. Back to manual insert mode Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #625430 5th Mar 2022 4:02pm
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Dr Rob - same here, removed mine. I suspect some of the cheaper extension leads do not connect to all the pins (also an issue with some scart extension leads). 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #625438 5th Mar 2022 5:10pm
DrRob
Think you're right. It also stops me looking at too often Laughing Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #625460 5th Mar 2022 9:40pm
