![]() | Home > Maintenance & Mods (L322) > Air con pulley or tensioner |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 ![]() ![]() ![]() |
Had my air con re-gassed today and was told that the pulley belt isn't turning the air con pump but the belt is still in place?
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2064 ![]() ![]() ![]() |
When I got my TD6 the pulley had siezed. I could not get it out so it went to my mechanic and in the end he took the compressor off |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Easy job. DIY! They use a sprung loaded shock the thing to keep constant pressure and tension in the belt. |
Thats the 1 that had siezed on mine |
if the tensioner is seized then the belt wont be turning right?
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
You can access from underneath by removing the front guard first. |
What Richcl said. I took the fan and cowel off as well just to have extra room and to allow the belt to go on easy without feeding it over the fan. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Is this the thing that is supposed to go click when you turn on the A/C?
You must have a leak in the system Joe90, most probable culprit is the condenser |
Not been using the FFRR due to good weather, but took the opportunity today to dive underneath and see what was going on.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35729 ![]() ![]() |
dont know about 1 and 2 joe,
@ Joe90:
ogy Member Since: 24 Sep 2010 Location: Yorkshire Posts: 50 ![]() ![]() ![]() |
I have had a similar problem. mine was as follows. the air con compessor has a magnetic clutch which pulls an outer cover pulley inwards on the compressor to drive the inside shaft of it. when looking at the comp pulley you should see a central bolt head. a common problem is this bolt comes loose and the front of the pulley falls off. mine was still sat on the bottom cover and simply bolted back on. if you look at the pulley and can see a threaded hole youve lost the outer clutch pulley.The picture in the earlier post showing the compressor shows a small circle in the centre of pulley this is actually a hexagonal bolt head. I think you will have to buy a new pump if the cover is lost as it is not available seperatly. I would get a cover from a breakers,much easier than changing the comp. Adam. |
Slow worker but finally got air con looked at (after the hot weather in April things cooled off so not needed ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
