Home > Technical (L322) > Auto box holding gears too long.??
Baltic Blue
I have just completed my first proper 80 mile round trip in BB since the easing of lockdown rules.
It seemed very reluctant to change up gears as I got speed up and even at 70mph was doing 2000rpm until I eased off slightly then it selected a higher gear and was much happier ... I hit my 80mph speed warning doing approx 1400rpm, but at lower speeds still seemed to be in too low a gear.
I know that these 8 speed boxes learn driving habits to some extent, and I am wondering if it has somehow come to think that I only drive to Tesco and back
Has anyone else noticed anything similar??
Next time I get out I am going to manually paddle through the gears and watch it change to make sure it knows 6,7 & 8 exist. and hope it reverts to pre lockdown selections.
Post #589877 1st Apr 2021 4:01pm
They do that when cold to help warm up times, maybe whatever tells it how hot it is is playing up... Pete
Post #589879 1st Apr 2021 4:19pm
Baltic Blue
Thanks Pete for your thoughts....
I was thinking maybe the selectors have somehow got a bit sticky with oil thickness having not been run up to normal driving temperatures for such a long time.
Paddling through the gears may ease them off ?.
Bow down Bow down Come back RR Phil Big Cry
Post #589881 1st Apr 2021 4:27pm
CS
My 2012 WM held on to lower gears once coming down a steepish section of a (paved) hill road, revs way too high (engine then well warmed as had travelled approaching 100 miles). I thought it felt wrong and changed up using the paddles, maybe another three gears. It never did it again, so the cause remains a mystery. Maybe a software glitch that cured itself when the car was switched off and then on again? If it does it again maybe reset the gear change software? That would also put it back to the factory default setting. Only Range Rovers since 1988
Post #589895 1st Apr 2021 7:30pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
I’ve come to the conclusion the 8-speed unit is a very good gearbox...once warmed up. Ours hangs on the gears when cold for far too long IMO and almost feels / sounds like a CVT box. But, once warmed up (after a proper drive) it’s wonderful. I take over and use the paddles when it lets me.
I’ve driven 2 E-class Mercs with they same ‘box and they has similar characteristics - harsher low gear shifts when cold. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #589896 1st Apr 2021 7:41pm
Baltic Blue
I had done 80 miles , mainly dual carriageway open road, but it didn’t improve by time I got home.
I had been so looking forward to getting back on the road, but it spoiled the trip.
Can a Gap iid reset the gearbox to factory settings ?
It will be a last resort if it can, but I will have to try it if it doesn’t improve over the next couple of weeks.
Post #589897 1st Apr 2021 7:42pm
CS
Not sure re the GAP iid, but dealers can definitely do it, my 405 had a problem (known/common) where on kick down the lower gear did not go in quickly enough, when it did eventually do so the revs were up and it came in with a bang, that was cured by a reboot of the gear change software (under warranty). Only Range Rovers since 1988
Post #589899 1st Apr 2021 8:19pm
General
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Have you had the gearbox oil changed?
Mine was coming upto 80000 miles and it was hanging onto gears.
I changed the oil and filter and it has been spot on since.
Post #590031 2nd Apr 2021 8:34pm
Baltic Blue
The gearbox oil was changed at 60k, now on 77k, so only done 17,000 miles.
It was perfect before being stood in lockdown for 3 months but definitely not happy now.
Post #590039 2nd Apr 2021 9:19pm
Baltic Blue
FIXED....
A decent length run this morning with many ups and downs on the paddles then ,back in Auto all seems OK.
I feel much happier now BB back to normal.
Post #590104 3rd Apr 2021 1:41pm
mjdronfield
Nice one. Normal service resumed.
We will all be able to get out and about more soon.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #590105 3rd Apr 2021 1:54pm
4040
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Mines not as sweet as it was a year ago. It’s only done 70k and I had the oil changed before Christmas.
I have been using the vehicle for work but not any other trips due to the rules etc. The trip to work is only about 6 miles, so it’s had pretty much a year of very short trips. Perhaps they don’t like this to much.
Once the rules change I shall take it for a good run and see if it helps.
I did notice that it reved a lot higher when I had my small trailer on the back, you would think it had a horse box on. Once unplugged it went back to normal so a computer is in charge somewhere!
Post #590154 3rd Apr 2021 9:23pm
