Home > Maintenance & Mods (L322) > Squeaky noises - rear wheel
sergeiicz
Czech Republic 2002 Range Rover HSE Td6 Epsom Green
Hello can somebody point me what these squeaky noises cold be?
Mostly at low speed on small bumps - town is worse and when raising to off-road height
https://youtube.com/shorts/x4DII9NqKN4
Thank you
Post #589234 27th Mar 2021 3:16pm
Could be the rose joints on top and bottom of the hub. There is nothing that can't be fixed with a hammer😜😜
Post #589236 27th Mar 2021 3:25pm
maric995
Croatia 2006 Range Rover HSE 4.4 V8 Zambezi Silver
hi,
My car produced exactly the same nose from the rear right wheel, all quiet now after rear upper bush was replaced (part number: Lemforder 2888101, easy to change if you have tool press for bushes. Smile RR HSE 4.4 2006 LPG
Post #589291 27th Mar 2021 10:32pm
sergeiicz
thank you i will look at these bushes, could you please confirm for me if this axle bush is what you mean?
(its pretty hard to find it with this PN in my country)
thank you
Post #589831 1st Apr 2021 11:30am
maric995
Yes, that's the squeaky bush that produced all of the noises in my car, and I could also feel it loose when I shaked the rear wheel by hands. Smile
you will need tool for changing it, some say that bush tool from vauxhall vectra fits good for this, but I used generic china made bush tool set from ebay Smile RR HSE 4.4 2006 LPG
Post #589836 1st Apr 2021 11:47am
sergeiicz
its this one right? Is it safe to change it without damaging car geometry?
Post #589878 1st Apr 2021 4:09pm
I think the nut is the alignment, so changing it will throw out the geometry (camber) a bit. You can mark the bolt and nut position on the arm so when you put the new one in it is in the correct place.
Also to get a good guide if you use the clinometer app on iOS you can check the vertical position of the hub face with your phone before you remove it and check it is the same when you put it all back together it’s not 100% but will give a good guide! Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #589889 1st Apr 2021 6:15pm
sergeiicz
Thanks already marked position before and tried to lube both bolts and nuts all with bronze vaseline/lubricant but nothing changed :/
still cant find these bushes on stock ... so these are coming with new bolts too right?
Thank you
Post #589891 1st Apr 2021 6:37pm
I’m not sure, but I don’t think they do.
Try robin at Duckworth Land Rover parts, Robin.Hall@duckworth.co.uk
Will send genuine parts and will be able to get the bolts for you, mention the forum and there is a discount. Normally also offers aftermarket options too. As far as I know will also ship abroad, subject to cost. There is nothing that can't be fixed with a hammer😜😜
Post #589906 1st Apr 2021 8:42pm
mandelbug
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Thank you
I got the bush from Island 4x4 when I did mine, didn't come with the bolt I had to order it, but it ended up the wrong bolt so didn't use it.
There is a good guide on the Wiki for changing them that I followed, bought myself a Chinese bush tool set (2 cups and a long threaded bar) from the bay of E. Worked well, although I didn't have exactly the right size so now it's more cone shaped than cylindrical.
Post #589974 2nd Apr 2021 11:42am
