![]() | Home > Technical (L322) > Check real lights - Dash Error Message |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34975 ![]() ![]() |
the GAP iidtool can switch off hot and cold bulb monitoring ..try a battery reset first. ... - .- -.
Ashmyster79 Member Since: 07 Nov 2020 Location: Essex Posts: 240 ![]() ![]() ![]() |
Hi stan.
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 83 ![]() ![]() ![]() |
I put a set of what sounds like similar items on my 2005 VSE last year, and whilst the looks from the outside were of a good quality item, I quickly discovered two problems.
100%. Whilst I haven’t seen what lights are on when I am driving I do think perhaps I will swap the internal units over and see if that works. The bulbs were different in the new ones sent red opposed to the silvery blue ones I had on the old lights. Also it was the lense that was cracked on one side. I didn’t realise you could buy replacement lenses. Cheaper too!!!
