![]() | Home > Technical (L405) > Tailgate Closing |
1JBS Member Since: 18 Feb 2014 Location: Henley on Thames Posts: 174 ![]() ![]() ![]() |
These are complex and have a number of sensors in both lower and upper sections that can go faulty, not expensive to replace but can be tricky to fault find... |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
I'm glad my tail gate is the old fashioned manual, there is less to go wrong. |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 627 ![]() ![]() ![]() |
Does the lower section close if you press the top section button? It should of course. The only time mine hasn't worked is when the battery was low on charge. Never been a problem with full battery or engine running. Mike - MPx 2017 5.0 V8 Supercharged SVAutobigraphy Dynamic SVO Palette Grey (2021-...) 2012 5.0 V8 Supercharged Autoboigraphy Orkney Grey (2017-2021) 2007 4.2 V8 Supercharged Vogue SE Tonga Green (2012-2017) 2002 4.4 V8 Vogue Bonnatti Grey (2008-2012) |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3926 ![]() ![]() ![]() |
Mine occasionally fails to close at all - I just press the unlock button. This often does nothing as the car may already be unlocked but then the tailgate closes - spooky! Geoff |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
To confuse things further Lr changed the functionality of the tailgate by model year.
Flyingscotsman1 Member Since: 02 Mar 2021 Location: buckinghamshire Posts: 26 ![]() ![]() ![]() |
Mine works ok if i press the unlock on the fob then the tailgate button on the fob weird |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1503 ![]() ![]() ![]() |
Mine had an issue a few months back, would just bleep at me and not close so had to do manually. resolved by dealer very quickly, it was the sensor strips either side of upper tailgate that needed replacing, all good since excellent work from local dealer |
Cheers for all the replies will get it booked in for testing |
Gazm007 Member Since: 22 May 2019 Location: Surrey Posts: 37 ![]() ![]() ![]() |
Ive got a similar issue where both tailgates start to close, then i get a bleep and nothing! |
