![]() | Home > Maintenance & Mods (L322) > Any got Aero windscreen wipers? |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Mine had them on and I experienced a similar thing, also had that on another car. I just removed them and went for standard Bosch 808. They are perfect and stay put and effective at up to 120mph in my experience and have no reason to doubt it won’t stay like that beyond it. |
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
I have these and I've had no problems at any speed or in any conditions.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
Thanks.
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 236 ![]() ![]() ![]() |
+1 for Bosch 808. Can’t fault them. |
If I get the same issue with the RDX ones, I'll get the Bosch 808s. |
tvrforever Member Since: 09 Feb 2016 Location: Bucks Posts: 55 ![]() ![]() ![]() |
anyone having any joy sourcing L322 flat aero blades at the moment? Advanced Factors are out of stock of the "BV2626S DKC000040 FLAT BLADE CONVERSION SET BV2626S LAND ROVER Range Rover L322" that I used to buy from them |
I got fed up of the noise from the Aero blades and went back to Bosch 808. 2015 Range Rover Autobiography 4.4 SDV8 |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
Literally just placed an order for these in the Black Friday sale: https://www.recambioscoches.es/champion/7547984
Really if you can’t find Aeros then try the Bosch 808. They’ve been absolutely perfect. I had terrible weather last month on my way back through Germany and the Netherlands and Belgium. They were absolutely perfect as ever, very well planted, even at very high speed on the autobahn, and most importantly kept the windscreen clear. |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342 ![]() ![]() |
deleted |
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
Problem is if you've already put the flats on, you'll have chucked out the adapters required for the 808's and they don't come with them.
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
I never can understand the logic fitting "aerowhatsits" to any vehicle.
Mine had worn aeros on it when I got it, I got an official 808 set and it was just hook and slot. So I guess there are different packs for the 808s or how Aeros get mounted ![]() ![]() |
My experience on my Mercedes is that they are considerably better at taking the form of the screen and clearing it.
