Back story
About 6 weeks ago driving along thought my 2005 TD6 was down a little on one corner . Had a counter sheer , just. Forgot about it until next drive when it went down on to the bump stops while set at Highway height. Fiddled around with it and got it to lock in at Standard height & drove fine.
No faults recorded & suspected air bag gone.
Replaced both front struts & rear shocks
Now front left sensor fault . Now replaced
Current issue
Fitted new sensor & wiring plug ( Left hand front )
Now up in the air on Standard Height ; Suspension lock button locked can't unlock. Pressed many times
[b]Air Susp Inactive[/b] displayed on dash
From IIDTool
[b]ABS - Brake Module[/b]
0 x 8A Air Suspension System CAN error
[b]EAS - Suspension[/b]
0 x 1E Front Left Height Sensor fault
[b]IP - Instrument Pack[/b]
0 x D7 Fuel Sender 2 fault
0 x BD EBV Function fault received from ABS ECU
[b]LCM - Light Control v12 +[/b]
0 x 57 Air Suspension Active / Inactive
[i]Line Values[/i]
0 4 Current Height - 9739 247 Current Calibration
4 6 Current Height 134 134 Current Calibration
Thought all my problems would be over. But not so.
[b]HELP[/b] Where to from here[/b]
