Home > Maintenance & Mods (L322) > design pack exhaust trims
Danwilderspin
Hi all
I am stuck and angry...
My existing design pack exhaust trims had all corroded so I bought some new ones from powerful which seem prettt much identical.
Anyway I’ve mounted them and the just look Censored , they are on the Censored and have big gaps.
As the majority of the alignment is done on the trim pieces above, do these ever get warped with heat or stress which could cause this issue as I am stuck and annoyed as it looks worse than before now
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #590308 5th Apr 2021 3:02pm
mjdronfield
I don’t have the design pack on mine admittedly, but they look a different shape.... might be wrong.
How do they compare to your originals shape and dimension wise?
Perhaps you can get your original ones coated or something.....
I’m sure I saw a similar thread on here recently..shape wise, was just going by this pic....
https://www.fullfatrr.com/forum/topic50133.html?highlight=tips 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #590310 5th Apr 2021 4:17pm
Danwilderspin
They look pretty much the same shape but I didn’t have the catch cans on the back of the originals they were originally blanks and I took the plate out. I’ve had them recoated once about 3 years ago just thought these may last longer Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #590311 5th Apr 2021 4:31pm
yours look the wrong way round and upside down Dan... ... - .- -.
Post #590312 5th Apr 2021 4:49pm
mjdronfield
I wondered that as well Stan, but wasn’t sure enough to suggest it.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #590315 5th Apr 2021 4:55pm
Danwilderspin
I wish they were but the bolt holes are only in one place I will take a pic close Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #590363 5th Apr 2021 7:55pm
mjdronfield
Sounds like you need a Plan B, involving the original ones, if nobody comes along with better help....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #590367 5th Apr 2021 8:04pm
Danwilderspin
If the mounts on the trims are warped from heat could this cause my issue?
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #590369 5th Apr 2021 8:21pm
Merchy
Without seeing all the bits - assuming that the bolt holes are in brackets fixed to the new tips, then enlarge the bolt holes a little and bolt on, using bigger washers if needed, may give you 'wiggle' room to adjust the position.
Just a guess, hope this helps.
Oooopppss, disregard my idea, posted this and had not seen the last two photos
Post #590370 5th Apr 2021 8:27pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I would suggest buying genuine ones rather than cheap copies, that might be your problem.
Post #590415 6th Apr 2021 10:06am
Danwilderspin
The original ones I have seem to mount the same now they have come off which I why I'm now thinking the mounts have warped the heat and I disturbed them. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #590416 6th Apr 2021 10:07am
Danwilderspin
Ok a minor update - I got my powerfully trim replicas abs they looked almost identical except had slightly bigger clips...
Anyway went through putting them in and they still looked rubbish but one side looked good. I then realised on the exhausts ends ends rather than using plastic washers as spacers they had welded in threaded nuts, then once tightened I obviously couldn’t tighten into the top securing nut. I also may have bolts a little long but they were original.
With that information in hand I will try again and I will have a set of three trims for sale now too as they weren’t at fault 😂 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #590764 10th Apr 2021 12:07am
Danwilderspin
Ok update
Loads better now - maybe a little tweaking if I can be bothered but it’s 95% there...
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #592489 26th Apr 2021 11:01pm
mjdronfield
That’s much better.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #592492 26th Apr 2021 11:11pm
Merchy
Sorted Thumbs Up
Nice job, One quick question if I may, have you put new Range Rover letters on the tailgate ? Those you have are the colour I need for the front of mine, but I don't know the exact colour to order, or which supplier to use, different suppliers seem to change the colour slightly. Cheers Thumbs Up
Post #592494 26th Apr 2021 11:26pm
