Home > Technical (L322) > Handling different L322 2010 and 2012
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
jim4244 wrote:
When it says the bottom of the wing what are we talking about here? To the top of the wheel arch or inside the wheel arch where the suspension is?
Jim
I used to the top of the wheel arch. I actually made a little tool. Got some old wheel center caps, dremmelled a slot in them. And then put a little bit of metal in them to stick out at 90 degrees. Then put my leica d2 laser measuring gadget with the angled hook right under the top arch and pointed the laser to the center of the wheel cap. Gave a nice and precise measurement...
Post #590428 6th Apr 2021 12:50pm
Bl4ckD0g
Weegie wrote:
Bl4ckD0g wrote:
What is motorway height? Never seen that on my L322.
Over a certain speed the suspension lowered automatically. With the earlier cars, my TD6 had it, it was at 65mph. Later ones the speed for activating it was increased to, I believe 100mph. Don't know if it continued through all the L322 years.
On the TD6 there was an indicator on the console which showed what state the suspension was in.
Nothing on my TDv8.
Yes, I suspect it was on the earlier models only. Just like ability to set different heights. Either that or mine is broken as I have definitely done those speeds Wink
I'm also not entirely convinced that those standard ride height values are correct for 2010+ model years. I've seen them before and I used them at my first attempt but it didn't look right to me. It seems to have the car too high and it looked a bit silly. I just took the liberty to shave off some height and make it visually more appealing.
I'm pretty sure this is what the default ended up looking like, which is too much 'monster truck' look for my liking...
But then, just for fun, I took it to the other extreme and brought it down (too) low....
And from there I just levelled the car to a height that looks nice, keeps the wheel archers filled, and still has scope left for both entrance mode lowering, and offroad mode raising.
I'm not sure that absolute values are that useful to share as there is some relative variation in it to level the car. But the GAP IID tool, makes this all pretty easy. And once happy with the standard ride hide, I then added the presets to the app so I can turn it into a low ridere or an offroad monster truck Rolling with laughter But everyday driving on my 22" with Pirelli's and active dynamic suspension is really nice...
Post #590429 6th Apr 2021 1:04pm
these are the heights [same as the chart already posted] from the 2010-2012 WM so your adjustments must have been wrongly applied,
Post #590431 6th Apr 2021 1:18pm
Bl4ckD0g
Yup I'm sure I've made the same mistake several times and remeasured them wrong again Laughing Which ever way I did not like the monster truck look, nor the handling it ends up with using those values.
Post #590435 6th Apr 2021 1:30pm
Cedwat
France
Just to be sure.
You would take measurement like on this picture?[/img]
Post #590450 6th Apr 2021 2:14pm
Bl4ckD0g
That is what I did. But according to Stan I did it wrong. So perhaps wait for someone to clarify on how to do it correct Wink
Post #590462 6th Apr 2021 3:34pm
