Home > Maintenance & Mods (L405) > Range Rover hood letters |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 354 |
Cut the template between each letter, and then put the template pieces over the existing letters on the bonnet then tape together - hey presto, perfect spacing. Current:
8th Apr 2021 7:53am |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 378 |
Thanks Z! I'll give it a try. |
8th Apr 2021 3:08pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34913 |
evoques are smaller in size so it possible you have a set for that vehicle.. ... - .- -.
8th Apr 2021 3:39pm |
Hi Stan, The letters are the same size but the spacing is closer. Is that what you mean?
8th Apr 2021 3:48pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7629 |
Are you sure the ones already on are correct?
8th Apr 2021 3:56pm |
Yes they appear to be correct. As I mentioned, the dealer installed the letters over the new 3M clear bra but installed them about 3/4" off center. I also checked with my wife's 2014 and they are also correct. Just have to cut template as D suggested and see if I can get them straight. Dealer said they would redo if I brought down but its a 3 hour drive. Mike |
8th Apr 2021 4:00pm |
Flyingfocrs Member Since: 18 Oct 2016 Location: On the croft with the horses Posts: 93 |
I’ve done this twice now with the same result, my rear template was embossed “sport”
9th Apr 2021 12:26am |
Letters came out great! Cut template and then took measurements of all letters from the hood of my wife's bonnet. Thank you all again for your help!
9th Apr 2021 4:13pm |
