Home > Technical (L322) > 3.6 TDV8 Losing Coolant
garyRR
Here's the link: https://www.fullfatrr.com/forum/topic32601.html 2015 Range Rover Autobiography 4.4 SDV8
Post #590939 11th Apr 2021 11:03pm
TDV8 Paul
thank you, i had a read through, looks like an all day job..... ill wait until the Mrs goes back into the office so i can do it in peace Laughing 2007 TDV8 Vogue SE
2005 BMW E63 645ci
2009 5.0 Supercharged autobiography
2024 Porsche Macan
Post #590944 11th Apr 2021 11:12pm
garyRR
In a workshop with all the correct tools, I'm sure it can be done in 4 hours.
On a driveway, definitely an all day job. 2015 Range Rover Autobiography 4.4 SDV8
Post #590945 11th Apr 2021 11:14pm
TDV8 Paul
Yeah, I was worried someone would confirm that 😂 2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #590975 12th Apr 2021 9:56am
garyRR
The problem has begun to develop a little more now.
I put it into the garage who said they found pink around the thermostat housing but, when they did a pressure test on the coolant system, there was no leakage.
Before, I had no smoke. Now, I'm getting a humid grey sooty smoke out the back that isn't the original black diesel soot I was getting caused by the vacuum pump. When I give the throttle some welly, the coolant level drops in the expansion tank and the grey smoke comes out the back.
If the thermostat housing was leaking, I'd say this should be identified on a pressure test so, whilst it may need replacing at some point, I'm not convinced this is the cause.
There's still no milkyness on the oil cap or dipstick, no sweet smell and no overheating.
Does anyone know how the cooling system works on these?
I'm thinking the cause could be the EGRs or EGR cooler or is there an exhaust gas cooler, where the coolant is making its way into the exhaust gases? 2015 Range Rover Autobiography 4.4 SDV8
Post #592334 25th Apr 2021 12:33pm
rar110
I had a slow coolant leak. A coolant stop leak fixed it. That was about 3 years ago, no leak since.
Admittedly I didn't find where the leak was. But there are so many places for coolant to leak. I love the 3.6, but the coolant lines go everywhere. Not a simple engine. ______________________________
Post #593238 5th May 2021 12:09pm
