Home > Technical (L322) > need your advice with my starting issue
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
hi all
could really do with some advice - ever since i got my range rover back in may 2010 it has had a small starting issue when its warm, all through winter i have had no problems what so ever when starting. The problem happens only once the engine has warmed up then stopped for a while e.g. gone shopping, etc.... when i come back to start the engine it sometimes has trouble starting, the engine turns over for 3-5 seconds then starts then sometimes it will stall straight away sometimes the oil light will flicker when starting but the oil level is on full and there are no oil leaks and the engine has no issues once running. When you turn the key again it will start straight away. First thing in the morning there is no problems at all, it only happens once then engine has warmed up, and if its warm weather. I have a faultmate diagnostic system and there are no registered fault codes in any of the ECU's - i was thinking that maybe the MAF sensor might be faulty but if it was should it register as a fault in the ECU? The car had a brand new land rover battery a few months ago so its not that
The engine is the BMW 4.4 V8 M62 engine.
Any help would be great, i really want to get this sorted as its the only real problem i have on the rangie that really worries me when it happens.
Matt
Post #58957 5th Apr 2011 8:36pm
bozmandb9
I can't really tell you why, but my first thought is Crankshaft position sensor. It's just ringing a bell with me, I'm sure I had a warmstart issue cured by CPS. Also the CPS wasn't throwing up a fault code.
I think I have a spare MAF if you need one. Tried replacing the MAF on my 4.4 but it didn't make a difference. Range Rover-less at the moment - Pining!
Post #58958 5th Apr 2011 8:43pm
like boz not sure but fuel vapour or fuel sensor spring to mind... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #58960 5th Apr 2011 8:44pm
dan_uk_1984
What if you leave the ign on for 5 seconds before starting? This will return the fuel in the rail back to tank and replenish with cold?
This would rule out the fuel turning to vapour?
Post #58965 5th Apr 2011 8:54pm
mattstevenson2005
I will try this starting tomorrow to rule this issue out
Matt
Post #58966 5th Apr 2011 8:55pm
mattstevenson2005
just been looking on the internet about the camshaft position sensor but most things i have read say that there should be some error codes stored.
Post #58974 5th Apr 2011 9:13pm
mattstevenson2005
Tried waiting 5-10 seconds for the fuel lines to fill didn't solve anything, I will record a video of the issue so you can see what it does.
Matt
Post #59107 6th Apr 2011 7:34pm
I would say it's a CPS fault
Post #59111 6th Apr 2011 7:39pm
bozmandb9
Again, I'm struggling to remember, but I think there are two sensors, one will throw up a fault, the other not always. But I'm pretty sure that this will be your answer.
Check out this link:
http://meeknet.co.uk/e38/BMW_E38_Case_Study_Fails_To_Start.htm
It's a very useful site, different car, same engine, many shared components, and Tim really knows his stuff! Have a look at the bottom of that page, where he refers to the CPS when it's not flooded engine problem.
If you have a look on the main page at meeknet.co.uk/e38 you'll find tabs for crankshaft sensor replacement, and camshaft sensor replacement, probably won't be completely accurate compared to the L322 version of the M62, but maybe close enough. Range Rover-less at the moment - Pining!
Post #59112 6th Apr 2011 7:50pm
mattstevenson2005
heres the video of an example of the starting issue, it struggled a little in the video but it has been much worse than this in over the last few days.
Matt
Post #59127 6th Apr 2011 8:32pm
Landrover Mad
2003 Range Rover Vogue Td6 Buckingham Blue
Another avenue I would investigate is the coolant temperature sensor, the idea of the sensor being that when the car is actually starting from cold the sensor senses this and tells the ecu to provide additional fuel (basically like the old choke system).
If this sensor stops working correctly it can fool the ecu into believing that the car is always starting from cold (even when it isn't, this means the ecu is telling the injectors to pump in a richer fuel mixture than is needed.
No fault code will be logged as the sensor output will still be within it's parameters (albeit stuck at it's lower parameter).
The good news is that a temp sensor is usually cheap and easily fitted, you can even test the sensor using a multimeter (looking for two different values for hot and cold) look up the following page for further info http://www.aa1car.com/library/coolant_sensors.htm.
Hope this is of some use.
Post #59131 6th Apr 2011 8:39pm
pretlove
i think it may be the maf sensor ...you could try cleaning the maf so that you could at least rule it out Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #59138 6th Apr 2011 9:13pm
A faulty MAf causes rough running but doesn't cause it not to start
Post #59151 6th Apr 2011 10:16pm
kb5
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Re: need your advice with my starting issue
hi all
Matt
Just a thought as I had the same issue a couple of years back --- I would check the Fuel Pump ! Wink
Post #61077 20th Apr 2011 8:25am
mattstevenson2005
does any one know a way of testing the fuel pump to make sure that it is this that is causing the issue? - just looked at the price and they are VERY expensive - although i could use a modified X5 part if the worse comes to the worse.
Matt
Post #61083 20th Apr 2011 9:19am
