![]() | Home > Technical (L322) > L322 fault help please |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
Could be low battery throwing up a fault but then turning on and off would go against that logic as takes some power to turn it on.
Cressys Member Since: 12 Apr 2021 Location: Yorkshire Posts: 2 ![]() ![]() |
Hi
Sound like it could be either a split top hose easy to check if you search on here, or if you are unlucky will be a split inlet manifold. If it's not the hose then you can check the manifold by spraying soapy water on it. One will be a cheap fix the manifold more like £800 ish. Current 2007 TDV8 Vogue Buckingham Blue |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Check intercooler hose for splits.
