![]() | Home > In Car Electronics (L405) > L405 TouchPro Duo No Sound |
| Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223
There is some info about this issue on the RRS forum and it says there is mention of the issue in the software update 19B. It may be worth you checking what software version you are on (I think I am on 20C) and making sure it is up to date
| Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 931
I see your car is a 2018 model. Is it the facelift?
| Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1412
Andy B
I think you might have to have the dealer activate SOTA All LR cars from 1984
Thanks Chalky
Yes sounds as if it has been enabled so they should be able to sort it out for you. Have you checked audio settings under the settings tab? All LR cars from 1984
| adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 877
Here are the fuses: https://www.fullfatrr.com/forum/topic58513.html
Chalky--Audio settings all checked it was the first thing I did.
It was the Amp Module that was frozen, solution was to remove Fuselink to reset system and update module.
Great! So, which FL was it? |
Adara
Thank you! I wonder whether these fuses are available as parts. The micro fuses are already hard to find... |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765
I had to get some micro fuses a while back and ended up at an auto electrics supplier. I think it’s a case of they aren’t sold at your general auto store and you have to get a bit creative when shopping for them.
I found them on aliexpress, the name is Micro M Rectangle Fuse PEC
